Ford 7.3L Gas Engine
/ Ford 7.3L Gas Engine #1
Tractorable
Marshall, Va
Tractorless, 2019 Toyota Tundra, 1980 Toyota Land Cruiser FJ40
Specs were just released on Fords new 7.3L gas motor, 430hp and 475lb/ft of torque. Cam in block push rod motor, forged crank, pistons/rods ready for boost, 4 bolt main bearing caps, cast iron block, built for durability, longevity, simplicity, and ease of maintenance. Makes 400lb/ft of torque at 1500rpm and will be mated to a beefed up 10 speed auto trans.
I like it, more power for towing than the 6.2L, and should last forever and be cheap and easy to maintain. I bet it’ll make a heck of a drag motor with a supercharger or a couple hair dryers bolted on.
We Finally Know the Ford Super Duty 7.3L V8 Power Numbers & They Are Lower Than We Thought! - YouTube
/ Ford 7.3L Gas Engine #2
Interesting. I sure wish when they do these interviews they would step away from the background noise. That said, I think it is smart of Ford to redo the big gas engine. :thumbsup:
/ Ford 7.3L Gas Engine #3
You shouldn't believe everthing you are told,I don't.
/ Ford 7.3L Gas Engine #4
I think it’s rated at 4000 rpm not 1500 but the 400 foot pounds seems believable.
/ Ford 7.3L Gas Engine #6
I think the old GM 8100 (8.1L) was 330hp at 4200rpm and 450ftlbs at 3200rpm. It was a real torquer but drank fuel.
/ Ford 7.3L Gas Engine #7
I have serious doubts about the new 7.3 gasser being any better. Big displacement high output gasser and good mileage doesn’t go together. The 8.1 hasn’t been produced in 10 years but I’d still think that over a Ford anything. I hope the scraped the duel timing chains and plug spitting problems.
/ Ford 7.3L Gas Engine #8
I don't know why people make a big deal about the plug spitting problem I have 2 v 10s and have only lost 2 plugs at a cost of 75$ a piece to replace. The motors have 425,000 and 497,000 and still going strong daily driver. No other engine repair done to them !:cool2: Best gas engine since the 460....:drink:
/ Ford 7.3L Gas Engine #9
Wonder what the gas mileage will be with it? I'm guessing maybe 15 hwy, 10 towing? If you gonna work the horses you got to feed them.
/ Ford 7.3L Gas Engine #10
Maybe in a 250. I’m guessing the medium duty truck is closer to 5 mpg loaded. I’d be surprised of it got 10 towing a big load in any truck.
/ Ford 7.3L Gas Engine #11
My 6.2 F250 only gets 11-12 hwy. I would think the 7.3 would be similar or worse. FWIW this is on a utility service truck with a rack on top.
/ Ford 7.3L Gas Engine #12
I'm really excited about this engine. I've run several V10's in my trucks and they've been great. Very inexpensive to own and maintain, and plenty of power to tow what I need. Which is to say, I usually tow my camper at 9k, and my equipment trailers at 12k-15k depending on what I have loaded on that particular day. I currently have a 2014 f250 with the 6.2 Gasser and 4.30 gears. That combination is pretty good also. not as much power as the v10s, but it holds its own for what I need. With the 6.2, I get about 14 MPG empty, and around 7-8 while towing.
For a person like me, and I would I think many other truck owners, these bigger V8 gas engines are a much better option than diesel. I likely will never own a diesel in these trucks again. The upfront cost and the much higher maintenance costs for long-term ownership makes them far less practical or economical.
I have been following the news on the new engine and I was hoping for closer to 500 ft/lb, but 475 still isn't bad. Better than the 430 ft/lb in my 6.2.
GM also has a new 6.6 liter gas engine this year, making torque in the 460 range. that looks like a good package also, however what I don't like about it is they kept the six-speed transmission and looks like they're only offering it with a 3.73 gear. If they would also have a gear closer to 4.30, I would be very interested in the GM also.
/ Ford 7.3L Gas Engine #13
Big displacement high output gasser and good mileage doesn稚 go together.
59HP/L is hardly high-output. HP typically requires more fuel than TQ, to create.
The EPA rating will probably be better than most expect, if you reference based purely on displacement. The commercial sector will love this new package, if it proves reliable.
/ Ford 7.3L Gas Engine #14
I don't know either, that statement generally comes from people that hate Fords.. How about the cost of replacing one injector on a duramax?
The plug problem has been overblown by GM fan boys for years along with the exhaust manifold bolts snapping..
/ Ford 7.3L Gas Engine #15
How does one compare a spark plug replacement to an injector replacement? That's like comparing apples to oranges, there is no comparison.
I'm a GM man (used to be a Ford man until I drove my first Duramax) and have never heard of a Ford spitting a spark plug.
/ Ford 7.3L Gas Engine #16
That is one **** of a torque curve. That thing will do just fine in the towing department. I bet Ford held back the power to give itself plenty of room to turn up the power as needed.
That motor checks all the right boxes...
Cast Iron Block
Push Rod
Long intake runners
Big bearings on the bottom end with 4 bolt mains and side bolts.
I've only owned Ford Diesels, but I will admit this is a contender.
/ Ford 7.3L Gas Engine #17
Time will tell with this engine, just like anything else new. No one knows at this point if it is good or bad. They haven't even showed us the internals yet. They are taking a step back to old school tech with a push rod engine....nothing wrong with that either. :2cents:
/ Ford 7.3L Gas Engine #18
Will there be an EPA rating on this? I didn't think they tested engines in the HDs and up.
/ Ford 7.3L Gas Engine #19
I'm on my 3rd V10... never any plug spitting problems..but the first 2 trucks both had manifold issues..and 1 ofthem had issues twice...1 had the heads replaced because the broken studs would not come out. ..and both of those were traded with under 25k on the odometer
/ Ford 7.3L Gas Engine #20
I believe that only applies to F450 size and up... Which is why the V10 has still been offered in F450+ up to and including this year.
V10 is in lots of tow trucks, school buses, RV's... Many diehard fans. In my opinion this engine has big shoes to fill (based on my personal experience). But I'm definitely impressed and excited.
Now... If Ford would only offer an independent front axle setup as an option to work on that harsh ride!
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
Gehl 125 Mix-All Feed Mixer (A64047)
Gehl 125 Mix-All...
