   / Harbor Freight Tools that don't suck #11,261
The bushings I used on that trailerball drawbar are standard Cat 1 to Cat 2 bushings, so the qhitch hooks must be Cat 2, while the overall side to side width of the HF qhitch is Cat 1. Well for various values of Cat 1. I have an early HF qhitch and I think the present ones are a quarter inch wider.
Yes, I recall seeing a HF Cat 2 qhitch in the catalog a while back. I hadn't noticed if it disappeared.
   / Harbor Freight Tools that don't suck #11,262
Ok, thanks. I've seen good prices, on the bushings, on eBay but some go Cat 1 to Cat 2 and some are Cat 1 to Cat 3 and think I saw Cat 2 to Cat 3.
I looked at the Cat 2 hitch 3-4 years ago and then it was gone.
   / Harbor Freight Tools that don't suck #11,263
MY HF quick hitch has Cat 3 hooks.
Bruce
   / Harbor Freight Tools that don't suck #11,265
Bruce
Ditto.
Just want to make sure we're all talking about the same thing here: the lower hooks down at the lower link arms that receive the implement's link pins. They are Cat 3 (1-7/16"+) on all the HF Cat 1 QHs now being sold. That's good, because it allows them to receive the dedicated QH adapter bushings that Northern Tool, AgriSuplly, TSC, Quality Farm Supply, et. al. sell: https://www.northerntool.com/shop/tools/product_200479426_200479426
Older HF Cat 1 QHs used to come with Cat 2 lower hooks, and can't be used with those adapter bushings. My first HF Cat 1 QH, which is probably 15 years old and still going strong, is that way. I just bush the pins on the implements I use most with that tractor up to Cat 2 with 1" I.D. galvanized iron pipe cut to length, with large flat washers on the hitch-pin end. That way they can still be used with the newer QHs on my other tractors as necessary, with only a bit more slop. My newest HF QHs, bought within the last five years, have Cat 3 lower hooks.
Regarding Cat 2 QHs, I, too, seem to remember HF selling them years ago. Northern Tool and others still sell them for about $170 and up. https://www.northerntool.com/shop/tools/product_200660649_200660649
   / Harbor Freight Tools that don't suck #11,266
Ditto.
Thanks for the clarification Threepoint.
   / Harbor Freight Tools that don't suck #11,269
want to make sure we're all talking about the same thing: the lower hooks down at the lower link arms that receive the implement's link pins. They are Cat 3 (1-7/16"+) on all the HF Cat 1 QHs now being sold. That ... allows them to receive the dedicated QH adapter bushings that Northern Tool, AgriSuplly, TSC, Quality Farm Supply, et. al. sell: https://www.northerntool.com/shop/tools/product_200479426_200479426
Older HF Cat 1 QHs used to come with Cat 2 lower hooks, and can't be used with those adapter bushings. My first HF Cat 1 QH, which is probably 15 years old and still going strong, is that way. ... My newest HF QHs, bought within the last five years, have Cat 3 lower hooks.
Interesting, thanks, I learned something new.
After the rollpins are driven in, the implement can't be swapped onto a different tractor that has original Cat 1 arms or an early HF qhitch. Seems to me this adds complexity, to no advantage.
Photo copied from a Northern Tool customer review:
59b80f97-7385-5502-9837-aac3d24b6338
   / Harbor Freight Tools that don't suck #11,270
You can drive the roll pins out with a properly sized drift punch. I did this after buying a Speeco Cat 2 hitch for my New Holland then taking it back several years ago.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
