What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #651
Today I got the goat house put in their pen! Did some bush hog work up till I found a lost bolder tomorrow I will fix the bush hog! Here is some photos of goat house they seem happy with it! 20190713_150926.jpg
   / What did you do on or to your LS Tractor today? #652
Today I got the goat house put in their pen! Did some bush hog work up till I found a lost bolder tomorrow I will fix the bush hog! Here is some photos of goat house they seem happy with it!View attachment 612876
Very nice! Is that old barn wood?
   / What did you do on or to your LS Tractor today? #653
20190713_145158.jpg20190713_145210.jpg20190713_145219.jpg20190713_145158.jpg20190713_145210.jpg20190713_145219.jpg
   / What did you do on or to your LS Tractor today? #654
   / What did you do on or to your LS Tractor today? #656
I took down old chicken coop/tack room used its wood to make goat house! Here are some before and after of coop!20190713_234654.jpg20190713_234957.jpg
   / What did you do on or to your LS Tractor today? #657
Very clever use of your straps!
I should have used a longer chain but knew that the strap on end of chain would work fine I purposely built the goat house open on both ends so I could see through it to drive lol and built it to be lifted like this with a chain over top you hook it to top of fork lift attachment with forks pointing down then as you tilt them up it tightens up makes it lift flat without worrying about it sliding around on forks! Not sure how heavy but enough that if I stopped to fast and back up with it in 2 wheel drive it would spin tires lol
   / What did you do on or to your LS Tractor today? #658
Good job 🤙
   / What did you do on or to your LS Tractor today? #659
My LS Dealer gave me screws with the big plastic knobs for the shields on both sides of the radiator, so it's "tool free". I'll get a picture in the morning.
That's a good idea, I'll have to order some.
   / What did you do on or to your LS Tractor today? #660
Well, What I did today? Something really stupid.
Got stuck. I'll post picture tonight when I get home. The mail man came to the door and got his car stuck in the ditch. the edge crumbled away. I got him out all ok. Then I saw a tree down up the road so I went and pushed it off the road onto my property into a shallow drainage ditch. I tried to keep the rear tires on the pavement. As I through it into reverse I started to rip the old pavement up and not going anywhere. so not to block the roar I drove it into the ditch to clear the road. I knew I could tow it out.
10222 (A56858)
10222 (A56858)
Toro Groundsmaster 4000D (A56857)
Toro Groundsmaster...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
