I was told it is a bad idea...hold my beer!
   / I was told it is a bad idea...hold my beer!
Just took a buddy on a hike to the top using the south side trail. He advised me to stop
   / I was told it is a bad idea...hold my beer! #222
Stop hiking or stop building trails?
In this photo, it looks like your cut-bank is about 100% slope (45-deg). It is really hard to tell what pitch your trail slopes are.
https://www.tractorbynet.com/forums...400-i-told-bad-idea-hold-20190503_122436-jpeg
I have added a bunch to my trails this spring, too. Not with my tractor, as the R4 tires can't really get up more than about 25% grade (3/12 pitch), and they are too narrow to drive on safely anyway. This season, I am using my new mini-X, and it seems to be able to get up about 40% max grade if the conditions are right. I am setting my max trail pitch at 33% (4/12), so I can walk it comfortably and get down safely in an ATV without sliding (new tires & 4x4). I use a 4-ft level and a 16" gauge stick to measure as I go.
Nice work! I wish I had a mini excavator.
He said stop with the tractorin' . The south trail is 35°-40°for most of it and no real digging. I'm just clearing brush going straight up a ridge. Now I'm into 45°/100% slope on that ridge. My R4s wont hold if muddy but will do ok when dry and clean. I'm barely managing and lost my ability to dig moving forward. I can only drag bucket point down, flattening 2ft each go. I should stop. I knocked a football size rock under one of my tires and about had to change my pants.
Cross cut trail, I've hit a large gully and not sure where to go. Build a bridge?
Prob cheaper to rent a mini ex for a week.
   / I was told it is a bad idea...hold my beer! #224
I either build a ford, a bridge, or lay culverts. I have all of these on my property.
I just converted the ford over my year-round creek with this culvert. I just scored some 24" PVC pressure pipe. I will prob have to sandbag it next fall, or it will flood.
Edging my way around the south side. 20190615_175434.jpeg20190615_190706.jpeg20190617_084151.jpeg20190617_084055.jpeg
I'm a little farther than this....I just forgot to take more pics after I put 9 more hours digging on the 4th.20190704_184849.jpeg20190704_154008.jpeg
   / I was told it is a bad idea...hold my beer! #227
Progress! Good job !
   / I was told it is a bad idea...hold my beer! #228
Yes quite the slope. For those of you flatlands... no disrespect intended, this is challenging work!
   / I was told it is a bad idea...hold my beer! #229
Looking great! Keep being safe - don't get complacent up there.
Did you make it to the top yet? Looks like your getting to a kind of plateau area up there, at least.
   / I was told it is a bad idea...hold my beer! #230
He said stop with the tractorin' . The south trail is 35ー-40ーfor most of it and no real digging. I'm just clearing brush going straight up a ridge. Now I'm into 45ー/100% slope on that ridge. My R4s wont hold if muddy but will do ok when dry and clean. I'm barely managing and lost my ability to dig moving forward. I can only drag bucket point down, flattening 2ft each go. I should stop. I knocked a football size rock under one of my tires and about had to change my pants.
How far up the hill have you progressed?...is this going to be a walking trail or do you have another vehicle (like a 4 wheeler etc) you're planning on using...?
2013 Ford E-350 Cargo Van (A55788)
2013 Ford E-350...
2006 International 7400 Tandem Axle Dump (A47477)
2006 International...
30008 (A53424)
30008 (A53424)
11' Container (A53316)
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
