pmsmechanic
Elite Member
- Joined
- Dec 6, 2013
- Messages
- 4,237
- Location
- Southern Alberta, Canada
- Tractor
- 4410 and F-935 John Deere, MF 245
Sounds like an interesting project.
Can you either provide a fairly detailed sketch of your system, or at least whether the water box is SEALED or OPEN? Thanks... Steve
you could tee off the 6" line into a 3" VERTICAL stand pipe, then let the TOP of THAT drain back into the water box for overflow to pond - this would keep your sprinkler pressure constant (assuming you don't run out of water, or add more sprinkler heads)
Weren't you gonna test your 6" line's pressure by a temporary cap and pressure gauge? That would tell you what that 6" line's static head is. If it's more than the 10 pounds you wanna gain, AND you have a way to support 24' of vertical 3" pipe, you could tee off the 6" line into a 3" VERTICAL stand pipe, then let the TOP of THAT drain back into the water box for overflow to pond - this would keep your sprinkler pressure constant (assuming you don't run out of water, or add more sprinkler heads)
Then, if you can find the parts, tie the 6" to the 2-1/2" in as STRAIGHT a line as possible, preferably thru a series of bell reducers for a more gradual transition. The "tall overflow" at 24' vertical will give you about 10-1/2 # more head than you have right now (actual head of water at sea level is 27.65" = 1 psi)
Kinda hokey, but physics-wise, it'd work... Steve
That is an interesting mostly fault-free pressure regulator (unless the pipe were to get plugged somehow.) Very interesting.
Agreed that finding the potential additional head is a first step. If there is, and since apparently there is a concern with extra flow spilling at the source(?). So I would consider this:
Connect the 6" to the 2.5". Rather than using a pressure regulator, add a T at that joint, pointing up, and add pipe vertically as needed to control the pressure. Excess can fall into the current water box. According to previous posts (I didn't figure it myself) 20' will give you the extra 10 PSI. This will only work if the source is more than 20' higher than the water box.
If you have less than the 20' of additional head, but close enough to make it worthwhile (maybe 10-15') put the T at the source, with a drain pipe (could be "firehose type", cheap plastic stuff) going to wherever it is that you can safely get rid of the extra, whether the current water box or whatever.
Crap, dnw64 - dunno how I missed your previous post ...
Crap, dnw64 - dunno how I missed your previous post or I would've pointed it out in mine; I don't like not being credited when I post useful stuff, and I try NEVER to do things to/for others that I wouldn't appreciate myself, so please accept my apology :ashamed:... Steve
