New to me Ford 1210 - Issues/Advice
   / New to me Ford 1210 - Issues/Advice #1
Hysyde
Gold Member
Eastern Ontario, Canada (South of Ottawa)
I've patiently been on the hunt for a few years for a CUT/SCUT and finally got sick of waiting and pulled the trigger on a 1986 Ford 1210. I had ideally been looking for something like a Kubota B Series or even a B21 TLB, but it was far easier write a check for about 30% of what one of them would have cost. It will mostly be contained to the 7 acres where my house is (we have bigger equipment on the farm) and it pretty much amounts to a toy that will allow me to landscape and haul wood from the bush (so hard to justify $20k +). CUTs/SCUTs under $10k do not stay up for sale long around here it seems they are few and far between, so even though the little Ford wasn't ideal, I bought it anyway and decided I could probably easily unload it if I wasn't satisfied and upgrade later on. The lack of power steering was a real concern for me, but so far it seems manageable. Hydro, 4x4, and a FEL were "must haves". The tractor came with a small 3pt blade, 48" rear Ford finishing mower, and a 48" snow blower.
That being said, it has been a real game changer for me as far as work around the house and it will get the job done. I have a lot of dirt I need to move around and landscaping to do on the property and I didn't have the option before. Plus I can keep my old Kubota locked up for the winter instead of punishing it with a snow blade on the front.
Several issues have immediately popped up, which I didn't notice while buying it:
It smokes like bastard. I would probably describe it as a greyish/white smoke/haze that smells like diesel (I think?). It's pretty noxious. The air filter appears clean, the oil is at the proper level (recent change to synthetic), and there does not appear to be any blow-by when I open the oil filler cap on the valve cover. It appears to do it at various RPMs and does seem to get worse under load. I'm hoping to have a friend come by who is a diesel mechanic and diagnose the injectors and pump, but anyone else have any ideas? I dumped a bottle of injector cleaner/conditioner into it, but it didn't seem to have much effect.
When parked and idling, there's a fairly apparent rattle/knock that appears to becoming from the transaxle that goes away when the clutch is depressed. I'm assuming it's a throw-out bearing on it's way out?
Other issues appear minor. Leaking FEL cylinder (cheaper to repair or replace?) and a newly sprung leak from on of the front axle final drives (not looking forward to stripping that down).
Also, is the requirement to use the glow plugs to start, even in the summer, normal? It starts fine once warmed up.
I have way more work lined up for this machine than I have time and I think I'll be happy enough to keep it around for now. I just don't need it to turn into another project! I'd love to hear from anyone with experiences with these machines.
I should be putting a ballast box on it soon (and losing the snowblower) as it doesn't like to dig without any weight (the rear tires are loaded). Either that or somehow add some weight to the rear scraper blade.
A small bush hog/rotary cutter should be in the future soon as well.
   / New to me Ford 1210 - Issues/Advice #3
get a tooth bar it will dig much better with teeth on the front...
   / New to me Ford 1210 - Issues/Advice #4
Did you get your issues squared away? I have a 1210 also.
Yes, I've taken care of most of the issues. Retimed the injector pump, new bearings and seals up front (not cheap) and new seals on all the hydraulic cylinders.
Blew a water pump this spring which I also changed.
   / New to me Ford 1210 - Issues/Advice #6
On my TC30 I have to use the glow plugs to start it - summer too unless it is already warm. - I was looking new as well, but went with used because it was so much less money involved. It was a good decision. These tractors are tough.
I should note that while it still needs the glow plugs for a cold start, even on the warmest day, it never failed or hesitated to start all winter when parked in an unheated shed. Even at -25C.
I try to avoid relying on just glow plugs and use the block heater, but there were a few times I was short on time.
   / New to me Ford 1210 - Issues/Advice #8
Yes, mine starts great also in any weather. Changed my water pump when I restored the tractor because it was leaking out the front.
Was spraying weeds today with a belton 3 point sprayer and noticed a leak around the bell housing. Think my rear main seal is shot. Not looking forward to that one.
   / New to me Ford 1210 - Issues/Advice #9
I had the engine out of my year 1986 Ford 1310 back in 2006 and it was not really that big of a job.
Hopefully you already have the shop manual.
   / New to me Ford 1210 - Issues/Advice #10
Yes, I have a shop manual. The problem is corrosion inside the bell housing. Mice set up camp in there for a few decades and severely corroded everything inside. Not sure if it will ever come apart at this point.
Here is a before and after from a few years ago when the resto was done.
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2008 Bobcat T190 Compact Track Loader (A55314)
2008 Bobcat T190...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
