What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #481
Homemade bucket forks work like a charm. :thumbsup:
   / What did you do on or to your LS Tractor today? #482
Step-son got into big trouble recently. So taught him to run the tractor and clean the chicken coop out. Yuck!!! LoL. Been a long winter in there.
Had him swap the grapple off, bucket on, clean the coop, then turn the compost pile with the bucket.
Planted corn. Used the subsoiler to open the rows instead of the Long Handled Hoe I started out with. Yeah, this thing has made me lazy(er).
   / What did you do on or to your LS Tractor today? #484
Almost had an uh oh trying to bush hog a too wet area... IMG_20190423_164541382.jpeg1556056027523.jpeg
   / What did you do on or to your LS Tractor today? #485
The 3-point top link hook makes an excellent holder for a funnel and tube to top off hydraulic fluid.
Rigged up the IBC tote metal cage for an FEL platform to help trim hedges tomorrow. Hopefully it won't .... you know ....
   / What did you do on or to your LS Tractor today? #487
Hey, I did same thing yesterday - will post pictures later
Worked without incident. Didn't go very high, just enough to get a better reach. Sure beats trying to reach off that ladder though.
If I wanted to go any higher, I'd have the BH on, outriggers spread and the bucket dug in.
   / What did you do on or to your LS Tractor today? #490
Just an FYI. I stepped on the front corner of the tote and lifted a rear wheel on the opposite side of the tractor. I was only about 10 inches off the ground so not a problem but ended up having to put 200 lb of counterweight on the back. I'm glad I I wasn't very high
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
Kubota B2301 (A53317)
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Air Compressor (New/Unused) (A59225)
Air Compressor...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
