Buying Advice Update on Purchase: Kubota M7060
   / Update on Purchase: Kubota M7060 #21
Again go back to the fat kid on a teter toter. The more weight on one end, the less weight on the other. In this case the rear axle is the pivot.
If you lift a heavy load & the rears come off the ground 100% of the weight of the tractor & whatever load is sitting on that front axle. And that pivot on the front axle is almost assuredly starting to tip setting you up to roll over in microseconds.
If you have a load on the 3pt (even better, way behind for more leverage) weight is transfered from the front to the rears, regardless of anything on the loader. That leaves 3pt weight + transfered weight on the rear axle.
Proper ballast on the 3pt isn't high. It's usually as high as the axle or lower. Box blade, tiller, even a rotary cutter are all lower profile than most CUT axles. In that case it's actually got a lower center of gravity than wheel weights or any liquid ballast over the axle centerline.
Somebody on TBN actually weighed axles attempting to disprove this (I think, maybe he was trying to prove it). He found the numbers showed a very noticable unloading of the front axle in all situations.
So is the answer #1 or #2??
This gets very complicated and difficult to understand.
Your teter totter example isn't applicable. If the tractor was weighted in such a scenario the front tires would lift off the ground when the FEL bucket was dumped. Doesn't apply in this situation.
Sorry for the thread drift.
   / Update on Purchase: Kubota M7060 #22
The teter toter aspect is still correct, even if 100% of the weight isn't being transfered. You end up with less weight on the font axle the more weight you have on the rears. That holds up no matter the load on the front up until the weight on the front can pull the rears off the ground. Then that extra weight ends up on the front axle as well.
   / Update on Purchase: Kubota M7060 #23
The reason the TT example isn't applicable is you only have, at the most, 2 ground contact points. With your tractor, before the load is lifted, you have 3. At the least with the TT, 1. At the least with the tractor, 2.
Your last two sentences make my point. Thank you for expressing it in a different light.
   / Update on Purchase: Kubota M7060 #24
Teter toter isn't a perfect analogy, but it's close. If you assume the beam inst anchored down it will be applicable if the beam hit a 2nd crossbar.
   / Update on Purchase: Kubota M7060 #25
I believe all you are describing is shifting the pivot point. Weight on (or in) the rear wheels simply just keeps the rear on the ground. It doesn't shift the pivot at all. Weight on the 3 point will act to shift the pivot point to the rear axle. Another way to look at it is shifting the center of gravity aft. The further out the weight is on the 3 pt, the more effective it will be shifting the pivot aft. Exaggerating this effect to the extreme would result in the front wheels coming off the ground and the tractor pivots on the rear axle.
HP
   / Update on Purchase: Kubota M7060 #26
HP
Very accurate.
I have carried too much weight on the 3pt and made the tractor dangerously light on the front axle when no load was on the FEL.
   / Update on Purchase: Kubota M7060 #27
Anyone have a problem with the PARK on this model ?
In particular if allowed to "roll into" the transmission lock on a slight grade it can be very hard to get it out of park.
On previous tractors there has always been a way to lock the foot brakes down - I can't find that on this one, either physically or in the manual, does it EXIST ?
   / Update on Purchase: Kubota M7060 #28
I do not have this issue with mine - on a hill or otherwise. This has been discussed in other M7060 threads. If your tractor is difficult to get in/out of park, your dealer may need to adjust your linkage.
HP
   / Update on Purchase: Kubota M7060 #29
My 7060 has no problems with the park, goes in and out easy.
On another note, y’all with factory cab/ROPS lights, where does Kubota put the factory light switch? Mine is a ROPS model.
   / Update on Purchase: Kubota M7060 #30
Factory light has the switch built into the light housing. The wiring pigtail is on each fender and is HOT when the key is on. I did not get the factory lights, double what nicer LED floods are and I was able to plug into the factory harness and run mine off a toggle switch to turn both on at once (key on only :) )
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
2007 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F550 XL...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A55788)
2019 Ford F-350...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
