   / Share Pics of People Hauling or Towing Something Wrong #9,551
I've heard some areas add it into asphalt for roadways too.
Hopefully the technology has improved. One of the last field audits I did before I retired was at a resurfacing project across the Mojave Desert where miles of asphalt paving that included rubber, had failed. Hot truck tires had lifted the paving and made long ruts. Removing and replacing that mess was underway when I did a routine review of contractor-payment source documents.
That was an enjoyable trip. The desert is gorgeous with wildflowers around Easter, pleasantly warm, near silent. That jobsite visit was as nice as a vacation.
The project engineer there wasn't pleased that somebody had invented this new paving material that wasn't suitable for his hot desert location.
   / Share Pics of People Hauling or Towing Something Wrong #9,552
No problems with the rubber infused asphalt in the VA climate that I've seen, seems to hold up pretty well.
   / Share Pics of People Hauling or Towing Something Wrong #9,553
That video had what is called a suicide load. It looks as though the driver may have survived, as the cab was forced forward and the load went over it. Usually the load goes through the cab. The driver would be in hurting shape though.
   / Share Pics of People Hauling or Towing Something Wrong #9,554
Proper and sufficient ballasting?
   / Share Pics of People Hauling or Towing Something Wrong #9,555
His front tire is all but flat
   / Share Pics of People Hauling or Towing Something Wrong #9,556
Looks sufficient, the back tires are on the ground. Plus he may not be able to raise the forks any higher to make it any more dangerous.
Front tires could use some air though.
   / Share Pics of People Hauling or Towing Something Wrong #9,559
Not the best idea in the world but guessing by the surrounding they most likely didn't have much to work with. Looks like a small residential job and maybe one rock to move.
Kind of like a ride on Dingo - you stand on the back of them and lift with the loader arms. Just better keep it low and slow.
   / Share Pics of People Hauling or Towing Something Wrong #9,560
Yep. He has four points of contact on an almost stationary object.
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2012 Freightliner M2 106 Altec AM650 50ft. Bucket Truck (A55852)
2012 Freightliner...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
23018 (A55758)
23018 (A55758)
