Jerking loader, 3 point hitch and weak front wheel assist
   / Jerking loader, 3 point hitch and weak front wheel assist
Thank you. I will check this out tomorrow! Could this actually cause the issue? Regardless, I will check it out and post results. Regardless, I should check this adjustment and make sure it is set correctly. I realize now that this is also in the operators manual!
   / Jerking loader, 3 point hitch and weak front wheel assist #13
You replaced all the loader hoses when one blew did you replace 1 at a time?
I replaced one and then just decided to replace them all...
I went through the process of adjusting the rear postion control valve. It needed adjusting. I also re-checked the hydraulic oil level and it was a quart overfilled!
I removed the oil to the full mark. The loader was much less jerky as was the 3 point hitch. I'm guessing the valve was not allowing full flow to the hydraulics?
The oil was thick, as you would expect at 19F but it was also a bit cloudy.
Perhaps the cold is playing a part now.
   / Jerking loader, 3 point hitch and weak front wheel assist #16
You may want thing about changing Transmission/hydraulic oil to a Cold Weather Hyd./Trans. oil like a synthetic. it definitely improves cold weather performance and cuts hydraulic noise. Because all Hyd./Trans. oil flows first through the Hydraulic oil Filter. With cold thick oil and with a Hyd. Oil filter being plug this restrict the oil flow to the pump. the filter may have be plug from medal filling when PTO gears failed.
   / Jerking loader, 3 point hitch and weak front wheel assist #17
I highly recommend it be change if you are keep using your Tractor Hydraulic in cold winter weather there is potentially cavitation caused by cold oil and this will destroy hydraulic systems.
Thanks I'll do that. I am unfamiliar with synthetic hydraulic fluid. Can you give me a recommendation. I'll change the filters as well.
   / Jerking loader, 3 point hitch and weak front wheel assist #19
I don't know what brand your oil dealers may have or have in stock . See if they can lookup the Manufacturer and model of the tractor to follow Manufacturers Specifications and refill capacity. You want a Synthetic All Weather Transmission Hydraulic Fluid. I have used in past Mobil Mobilfluid LT this might be called(low viscosity or low temp) Use New Holland Filter.
Or see if they can Cross References Mobil Mobilfluid LT.
Thanks I'll look into it. You provided me with some great information!
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
Deere 350G LC (A53317)
KOMATSU PC170LC EXCAVTOR (A52707)
KOMATSU PC170LC...
2003 Hyundai Elantra Sedan (A55853)
2003 Hyundai...
2016 Morbark Chipper (A55787)
2016 Morbark...
