Tire Overtreads--A Needed Invention
/ Tire Overtreads--A Needed Invention #1
glennmac
Western Connecticut
2003 Kubota L3430
The debate and indecision about traction tires vs. turf-friendly tires will go on until the heat death of the universe unless a new solution is invented.
How about this. You get ags. But then there is a rubberized tread that you can put on over the ag tires themselves. Like chains, but a nice snug fit that completely covers the ag tread. I dont exactly know how the attachment would work. The underside of this "overtread" would have a female indentation pattern that would exactly fit over the ag tread design. This would keep the overtread from slipping during tire use. The topside of the overtread would have a turf design.
You would leave on the overtread as your normal tread and take it off when you needed traction. An additional benefit would be that when you wore down the turf tread, you could just buy a new overtread instead of a whole new tire. The underlying ag tire would essentially never wear out because you would only be using it infrequently.
Feel free to tread all over this thought.
/ Tire Overtreads--A Needed Invention #2
Sounds great, but what if you wear the ags down and the turf top starts to slip? Just a thought. But if you can take up the play and they would stay on, it sounds like you need a patent lawyer now! When you get the prototype done I will test a set for you at no charge!
/ Tire Overtreads--A Needed Invention #3
I will do all the free testing that you want. Sounds like a good idea to me.
bubba
/ Tire Overtreads--A Needed Invention #4
Glennmac,
Isn't that just about what they do with bob cats to make tracks? Seems I've seen a few of them running around with what look like R4's with a track snapped over them.
The whole idea sounds good though, but I would suggest the base tire be a non-usable (otherwise worthless) propriatary tread. This allows the overtreads to be used ONLY with the manufacturer's specially shaped tire (thereby increasing the probability of getting a major manufacturer to accept your idea). Then, all different tread patterns could be purchased and applied to your base tire.
SHF
SHF, I dont know much about Bobcats so I cant comment. Your post made me think of something else. If the front and rear wheels of tractors were the same size, as I argue in my "Compact Tractors are Designed All Wrong" thread, then we could install machine tracks ("bogie" tracks) on our tires. Those are the things that wrap around both tires so you have like a tank or bulldozer tread. You can see them in the Labonville catalog.
/ Tire Overtreads--A Needed Invention #6
Glennmac, on a 4 wheel- drive machine, changing the diameter of one set of tires dictates doing an EQIUVALENT change to the other set. I assume those tracks (bogies?) would also mess-up the lead/lag on a 4 wheel drive machine. On a skid loader the wheels are the same diameter.
RCH
/ Tire Overtreads--A Needed Invention #7
Seems like you could use the bogie tracks on a vehicle with larger rear tires and smaller front tires, you would just have to increase the rotation speed of the front wheels to match that of the rear wheels. I though 4x4's usually had a different front/rear rotation speed anyway, but probably not enough to use tracks. The real problem with tracks would be-- turning. A tight turn might spin the track right off.
SHF
On my hypothetical tractor the wheels would be all the same size so the 4wd circumference ratios should not be an issue. Of course, with the bogey tracks you probably only need to be in 2wd to drive the tracks. How do you turn? Obviously you cant turn the front wheels. Is this the place for the lost art of brake steering?
Keep in mind that I know less about bogey tracks than I do about subatomic physics.
/ Tire Overtreads--A Needed Invention #10
Hi ya
Ya maybe be on to some thing there i don't know how ya would put them on tho, may have to deflate ya tires then slip them on .only other thing is have a smaller lawn then ya don't need turf tires:) or plan B have a small mower for the lawn and a bigger toy for dirt working
on another note about the tracks one of the tractors that went to the ice (MF TEA????) it was on tracks has a idler 1/2 way along the frame and still had wheels on the front (i think) i'll have to look it up ,it was a kiwi dude Ed Hillary a few years after he climbed the hill in the 50's-60's that had it made there was 4(?) made. 1 is still down there ,1 in kiwi land and i think 1 at MF in the UK i have no idea what happend to the other one tho.
catch ya
JD Kid
/ Tire Overtreads--A Needed Invention #12
Actually, the relative diameter of the front and rear wheels doesn't matter at all. By definition, they both traverse the same number of feet per minutes for any tractor movement. That's all that matters for driving a boogie trac or whatever they are called.
/ Tire Overtreads--A Needed Invention #13
Sorry but the math doesn't compute. An Example: If the front tires had a radius of 1/2 the rear and you rotate the front tires at twice the angular velocity then voila the desired 4wd situation (just as you assumed). Now add the accessories. The front and rear accessories must be of different thickness. Otherwise consider this: If the accessory thickness is say 10% of the front tire rarius that would be 5% of the rear tire radius and the new front to back ratio would no longer be 1:2 it would be 1.2:2.1 and the 2:1 difference in gear ratio front to back would not "fit" anymore. This would cause a problem with "tracks" or independent accessories on each tire, it doesn't matter which.
Another view: The distance traveled by the front and rear tires should be the same regardless of whether using tracks or conventional tires. The distance traveled by a wheel per unit time is the circumference times the RPM times the time spent traveling. An example: A wheel 1 ft high is: 1 times about 3.14 feet around. If it turns once per second then the axle progresses 3.14 ft/sec . If the back wheel were 2 ft tall then it is 2 times 3.14 or 6.28 ft around. It would have to turn one time in two seconds to go the same speed as the 1 ft high wheel. Now lets increase the diameter of both wheels with either a track or a tread cover thingy (it doesn't matter which). The principle is the same if the additional thickness is just a little bit or a lot so lets make it fairly thick and see a glaring error. Lets make the accessory a foot thick. Now the front wheel is 3 feet tall and goes 3 feet times 3.14 (9.42 ft) per revolution. The back wheel is now 4 ft tall and goes4 times 3.14 (12.56 ft) per revolution. Since the front wheel turns twice for every turn of the back it goes 18.82 ft while back wheel is going 12.56 ft. This might cause some tire scrubbing, loss of traction, wear, steering difficulty, premature tranny and drive component wear and bad things I haven't thought of yet. Of course the accessory will be less than 1 ft thick and the error will be smaller. Do the math, it won't be healthy for the things I listed above.
There was one tricky part. If you missed that you were on a colision path with reality. Adding twice the accessory thickness to get new "effective" diameter used to compute circumference. Consider the leverage thing. From the center of the axle to where the rubber meets the road is a lever arm, this is what the tractor "pulls" to go. It is also a radius of a circle. Increasing the radius adds twice as much to the diameter. If this wasn't so then the physics would be quite different (really wrong, but different). Accessory thickness would not matter as it would be the same as driving over a carpet or layer of anything.
So, if you run separate accessories on the tires and you had the correct thickness for your particular front to rear ratio you could run 4wd otherwise only 2wd. To run tracks you need to either run 2wd or get tricky and run a round tire accessory to adjust for the difference front to back plus tracks.
As a separate observation regarding tire wear. Grit, gravel, and mud will get between the accessory thingies and the tires, tracks or separates. There will be flexing and scrubing with this abrasive mix in there (I assume the need for these accessories was for other than tractoring in a clean room) will chew up the tires faster than regular tire wear by far.
If anyone cares, I vote with the enlightened gentleman a few posts back who said, and I paraphrase, it would be cheaper to get an extra set of tires and wheels. Sure would.
Now then, there is a company that makes tracks to replace the wheels on a 4wd truck. I have seen videos of a P/U truck flying up dunes in 4wd on four tracks. Steers just as it always did and the tracks clear the front sheet metal when steering. Comes in various models for different size trucks. Maybe they would provide tracks for a tractor. They tout the advantages of large footprint low PSI, goes good on snow, sand, soft ground etc. They were N OT cheap and couldn't compare to the price of another set of mounted tires but will do what N O tractor tire that will fit on your tractor can do regarding traversing soft footing. The demo I saw showed the truck driving up with conventional wheels with tracks in bed (pretty much filling bed) They jack up the truck one wheel at a time and put the tracks on. Put the wheels in the bed and then do some amazing dune climbing. Would be great to run the river sandbars, winter snow, etc. Of course it raised the truck like a good size lift kit which was not a bad thing for off roading but yoiu have to be mindful of the increase in height of CG and the traction They don't slide sideways to relieve momentum very well and would roll if you tried to do some Mario Andretti stuff. Probably wold work super on a tractor if yo didn't over stress them pulling something. Of course the MFG could supply safe limits I'm not experienced beyond seeing the demos.
Patrick
/ Tire Overtreads--A Needed Invention #14
Thanks for the Antarctic tractor story URL. Nice read. Ought to read it to my L4610 to inspire it to greatness.
Patrick
/ Tire Overtreads--A Needed Invention #15
Hi ya
Oh man i'm holding back the tears from my eyes LMAO got a pic in my head of ya sitting beside ya tractor with it all tucked up like a 5 year old listering to grandad's old time storys that aside i don't think MF used it as a selling point
catch ya
JD Kid
/ Tire Overtreads--A Needed Invention #16
I see where you're going with your reasoning, but I think it's incorrect. Tracks don't increase the diameter of the wheel. The wheels travel continuously around the inner surface of the track, not the outer.
Think of it this way. Take the track, cut it, and lay it out flat. Make it as thick as you wish. Now drive the tractor down it's length. As you get to the end, quickly run around the back, pull the track up over the wheels and around to the front so you drive over it again, and again.
/ Tire Overtreads--A Needed Invention #18
Hayden, I sure don't want to make an ememy so lets pursue this for fun, no money, no ego, not even a rootbeer float, OK.
Lets say the track is 15 feet long and the wheels are approximately 1.59235668789808917197452229299363 ft in diameter including the track thickness (twice). This would put the wheel base at 5 feet. Each rotation of the wheel would advance the axle 5 feet. In three rotations the track would make one full circuit around the wheels and baring loss of traction would advance the axles (and vehicle) 15 ft.
Now if we were eyeball to eye ball I could get an amen or you could dissagree and I would explain the hard part.
Now take the track off and lay it out on the ground. Just for grins, lets say the track is sturdily built and is 6 inches thick. The wheels then (sans track around them) are now approximately 0.59235668789808917197452229299363 ft in diameter. Each rotation of a wheel this size (whether on the ground or on carpet or rolling down the track we have put on the ground) advances the axle 1.86 ft approximately. Since 1.86ft clearly does not equal 5ft the axles advance different distances with track on and track off.
I'll pause here until my temples stop throbbing. I haven't had anyone force me to actually think in so long, I'm glad to find out I still can. I'm reminded of the lecturer who said, "If you make people think that they are thinking, they will love you but if you actually make people think they will hate you." I hope we both avoid his pronouncement.
Hayden, thank you so much for your question. I hope this cleared it up for you but if not A N D no other brave souls out there want to jump in, I could try to find yet another way. Or alternatively, you or someone else of your persuasion might want to try to explain my error. Maybe I just don't get it.
I used to have a chuckle every time some mathematician wanted to prove something so badly that their subconscious would introduce an error into their proof to make it come out the way they wanted. They would publish in a journal or deliver it as a paper in a convention venue. Someone would see the booboo, ream them over it, the author would publish a thank you for noting that error type of a message and resubmit the proof with that error fixed and another introduced to make it come out the way he wanted. Sometimes they finally prove it sometimes they go down in flames and never make the proof (it might not be provable). This is not an isolated event except it often happens at mathematic society meetings and not so often in journals.
Patrick
/ Tire Overtreads--A Needed Invention #19
Heat death of the universe? Now I have something else to worry about. So when is that supposed to happen?
I thought knowing that the answer was 42 would have been more useful but now there is this heat death thing. Is that for sure our universe?
Patrick
/ Tire Overtreads--A Needed Invention #20
Hi Hayden, I thought of another thing. If the relative size of the front and rear wheels didn't matter would that mean similarly that the relative sizes of the pulley wheels over which a fan belt kinda thing is stretched also doesn't matter and even though they are different sizes they would both spin at the same RPM or that changing one of them wouldn't effect the RPM of either. Doesn't a smaller one have to spin faster to move the same number of linear feet of belt or else it will be slipping? If both pulleys were gear driven from same motor wouldn't it matter what the two gear ratios were in relation to the sizes of the pulleys? Is this different from your envisionment of a tracked vehicle? If yes, how?
Patrick
2020 Hyundai Sonata Sedan. (A61574)
2020 Hyundai...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2023 Case TV380 (A62177)
2023 Case TV380...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
