John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,616
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
Yep. Around here buying wood is more expensive than heating with propane.
Cutting firewood isn't cheap and absolutely isn't free heat.
If you are putting a cost on your labor, it's certainly not cheap. However, I do it because I enjoy it. It gets me out in the woods. It's also an opportunity to accomplish some management activity on my property - whether I'm managing for wildlife habitat, or for timber value, or to clear a trail, I'm almost always getting something out of my efforts beyond just firewood.
A any rate, in my area it's a moot point. Natural Gas is not available, and the other costs are all much higher than heating with my wood stove (other than putting in a Cold Climate Heat Pump, which probably gets close).
Some folks may find this heating cost calculator of interest: put in your fuel cost for various fuels, and your appliance efficiency, and you get the costs per MBTU. (NOTE that modern wood stoves often list efficiencies well about the default shown. However, those tend to be best efficiencies under very good conditions. Few people actually achieve the rated efficiency on a wood stove or boiler.) Of course, the big swing is what you put in for your cost of firewood. If you are buying, that's easy. If you are cutting your own, that's a matter of some debate.
Here's another heating cost calculator with more options for heating sources. Unfortunately, this one does not let you adjust for efficiency, nor do they tell you what efficiencies they are assuming.
