Marijuana on the job
   / Marijuana on the job #1
ddbackhoe
Md.
DK5310SE HSTC
The new trial and error problem, how do you cope with employees that now can get �edical marijuana cards. We have a zero tolerance policy in place, but not sure how much longer that will be enforceable. Read an interesting article today on the topic, what are your thoughts/opinions. Letting employees/staff get high or drunk on a construction site is not the acceptable answer. :rolleyes:
Don’t Let Your Business Go Up in Smoke
   / Marijuana on the job #3
Also, consider that HIPAA laws may not even let you know if they have such a card or are taking legal medications.
   / Marijuana on the job #4
Your company should put into place policy regarding alcohol and drugs, both legal and illegal.
And they should put into place drug and alcohol testing policy after any incident that results in personal injury or business losses.
Those policies should be clear and concise, with spelled out discipline up to and including termination.
I recall I had to take pain killers at work one day. Prescription meds. I started feeling kinda loopy pretty quick. Went to my boss and told him, hey, I took my meds and feel loopy. He told me I should go home. I said OK, but I can't drive like this. He said call your wife, take a cab, whatever, just don't do anything and get out of the building as soon as safely possible. Seems perfectly reasonable to me.
   / Marijuana on the job #5
If someone appears "under the influence" I would send them home. Does not matter if legal or illegal drug. It is a safety issue.
Much easier to do in a union plant. Example. There was a maintenance guy carrying a 2x4 stud in the plant who reported to me. he was carrying it across his body instead of how one would normally carry a long object down the aisle. I brought in the union steward and asked him to see for himself and talk to the man. Steward came back after about 30 minutes, and asked if the fellow could go home without making it an issue. Done deal.
   / Marijuana on the job #6
If you think they are under the influence you cant just send them home. You can see to it they get home safely.
Been there in union shop, If you take them home and have an accident-you are liable, send them home and they have an accident-you are liable for sending them. If you send them home and try to fire them for being under the influence you will lose-if you felt they could drive home, then they could work. Where I worked it got so they would call a squad anytime someone needed any medical treatment because of transportation liabilities.
To answer your question it should be treated the same as any prescription med per your company policy.
   / Marijuana on the job #7
So far in this legal recreation marijuana state employers are able to deny initial employment to persons who do not pass an entrance test for all federal illegal drugs and alcohol unless supported by a prescription. After employment testing and continuation is per the company employment manual. Pays for employers to make sure your manual passes all employment legal situations up front not after an incident you cannot enforce or results in a suit against the employer. Due to safety regulations and liability insurers construction has these policies for decades. As a supervisor I always had union backing on those policies. I have heard that a lot of union contracts now place pre-employment testing with the union. You cannot be dispatched w/o a clean test.
Wonder where this will go in the next ten years as legalizing of drugs continues. Even opiates are not enforced in the city of Seattle where they have shoot houses with free needles.
Ron
   / Marijuana on the job #8
I have to report all medications to my employer. I am subject to random tests. 1st violation....termination,. It is spelled out quite clearly. Even alchohol. Spelled out in explicit detail . Test positive on the job..(there are specific levels).termination
   / Marijuana on the job #9
My company has a policy of NO prescription or otherwise drugs/alcohol on the job. PERIOD.
We are a construction company and have had that policy in place for 30 years that I know of.
1st offense, time off.
2nd offense, more time off.
3rd offense IF you admit you have a problem, then rehab.
If you get caught after the rehab FIRED.
Canadas' hiring and firing laws are different.
Even though I hold a MM card, I will NOT partake of it within 24 hours of going to work.
When April 1st comes I will stop taking the MM in order to be clean for the companies 'invasion of privacy', which will probably take place in May.
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
AEREATOR (A58214)
AEREATOR (A58214)
CASE IH 496 DISC HARROW (A52708)
CASE IH 496 DISC...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
