   / Harbor Freight Tools that don't suck #10,691
I have several of the meters. They all seem to have died over the years. Some of them don't even turn on any more. New batteries accomplish nothing.
Yeah... they're not the most durable thing out there. I bought one for about $5, got 3 more for free. If I'd actually paid real money for them, I'd be a bit more upset about the one that failed. The others vary from 1 to 4 years old and still working.
   / Harbor Freight Tools that don't suck #10,692
I've also had several. None have worked consistently. Some never worked.
   / Harbor Freight Tools that don't suck #10,693
I only tried one of the HF meters. First time I used it, both wires fell out of the plug ends. I tossed it in the trash. I guess I should pick up a couple more when I see them for free so I can give them another chance. I agree that having a 'not great but ok' meter always handy beats having an exceptional meter tucked away somewhere.
   / Harbor Freight Tools that don't suck #10,694
Really all I ever use them for is an 'is or isn't' test. Is there voltage or isn't there. Is there continuity or isn't there. I would never try to take a reading that really mattered
   / Harbor Freight Tools that don't suck #10,695
I got one of the free HF meters. It didn't work when I got it home. The Fluke in the workshop still works, so I use that. I bought it about 20 years or so ago for somewhere around $100. Are they $400 to $500 now?
   / Harbor Freight Tools that don't suck #10,696
95% (maybe 99%) of all electrical faults in the home do not require a wagging pointer to figure out what is wrong. I use a non-contact probe which is very safe and much faster and easier to use than a voltmeter. And a plug in outlet tester. Also much easier to use than a voltmeter. I do have a couple decades old Fluke meters, originally bought for fixing and building guitar amps, but seldom use them these days. I cannot see any use for a hit or miss, here today gone tomorrow HF meter. The one thing you really DO want in an electrical tester is predictable reliability, which they do not have.
   / Harbor Freight Tools that don't suck #10,697
Needle doesn't move. Either the circuit is dead or the meter is dead. :)
Bruce
   / Harbor Freight Tools that don't suck #10,699
I made good use of that ball joint press coupon and the 25% off this morning. I took my father out to breakfast and then ran to HF to make my calculated move.
I feel that this is actually a really great price at $59 for the ball joint press kit with the coupon and then the 25% off of the adapter expansion kit.
What I didn't know and I learned today is that no Maddox is lifetime warranty. And not all Pittsburgh or Pittsburgh Pro are lifetime. Only hand tools, as in told that you pick up and use in the hand. I'm not sure where that line is drawn because sockets, extensions and impact sockets are lifetime.... But the adapter expansion kit and the ball joint press kit are not hand tools and are 90 day only... Unless you pay up for the 2 year. I did not.
I'm not sure that I understand how or where that line is between lifetime and 90 days. 20181231_121552.jpeg20181231_121559.jpeg20181231_121634.jpeg20181231_121737.jpeg20181231_121843.jpeg20181231_121910.jpeg20181231_121928.jpeg1633_ITEM_BALL_JOINT_SERVICE_KIT_FOR_2WD_AND_4WD_VEHICLES_1545966466.8902-1.jpeg25_percent_off_1546010731.3402.PNG
   / Harbor Freight Tools that don't suck #10,700
I've eyeballed that ball joint press set but don't replace them often enough at this point. Plus some of my cars would get a full control arm over a new ball joint as no one sells just the ball joint. Last time I borrowed one from Autozone. I always need to watch the line between want and need seeing I have limited space and finances.
That Braun bar light for $20 may end up in my workshop though. The coupon is good for quite awhile.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
24017 (A56859)
24017 (A56859)
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
