hanson 3 point snow blower
/ hanson 3 point snow blower #1
johann
bx2200
I need some info on a 48" hanson 3 point snow blower is anyone familiar with this company? I have only found a thread or two talking about the blowers they made for pickup trucks, and that they were underpowered. the one I found is a 3 point so I would think it would be a different story since it would be pto and not a separate underpowered motor. I have not owned a 3 point blower before, so I could use some advise from some of you with experience with them.
I use my FEL all winter so 3 point is the only blower I can use.
/ hanson 3 point snow blower #2
If you could post some pictures that would be great.
The things you need/must have for the use of a three point hitch mounted snow blower are power, traction and adhesion, you need all three to work well.
You need either ladder link snow chains or v bar snow and ice chains and keeping the mule at PTO engine speed and traveling slowly in reverse on the first pass and then you can take half cuts on the next passes.
Lining the chute and spout with slick plastic from horn plastics using the sheet anchor bolts from Farm Tek will help you a lot if you use them.
Another option is using fluid film and Clarence's impeller kit to improve the snow blowers performance by 50 percent or more.
/ hanson 3 point snow blower #3
From the images I find on line for the Hanson product I would stay away.
leonz will probably disagree with me but, in my many years around and designing machinery as a mechanical engineer, the design with the gearbox in the middle of the auger is not the heavy duty product you need but rather a walk behind design.
Here is a photo of a center gearbox where the owner used too strong a shear bolt not realizing how weak it was.
There are tough old snow blowers around like this one which were made to last and can easily be cleaned up because the gearbox is behind the fan and made like the serious blowers used by many farmers.
Dave M7040
/ hanson 3 point snow blower #4
Hello Dave7040,
NOPE I do not disagree with you at all my friend not at all. The worm gear and spur gear system is best left to lthe walk behinds.
I keep hoping my JDLA115 and the snow blower it came with get stolen as I would rather have a 2017 yamaha 1028 track drive snowblower anyway if I can swing it.
/ hanson 3 point snow blower #5
double post GRRR
thanks dave that is very useful information.got any tips for checking out a 3 point snowblower that you can't test? The person selling no longer has tractor.
leonz you say I need chains, I plow with a 3 point grader blade without chains, I would think that would be when I need it more.
/ hanson 3 point snow blower #8
Thanks Dave that is very useful information.got any tips for checking out a 3 point snowblower that you can't test? The person selling no longer has tractor.
(if you can bring your mule to run the blower before buying it as a no load test high RPM test will reveal any issues)
If you buy the Hanson it will act like a boat anchor if it does not have substantial skis or skid feet and that is why you need chains and loaded tires.
/ hanson 3 point snow blower #9
/ hanson 3 point snow blower #10
Start with a few photos of what you want to buy here so we can look them over.
Rust is not an issue if the blower case is a thick steel and not sheet metal
I would find the two shear bolt locations, one on the pto shaft and the other on the sprocket that drives the auger, and look first for grade of bolt used, and second, if the bolt is a grade 8 (the one with many lines on the bolt head) I would remove the bolt(s) and for elongated or deformed holes which would indicate frequent impact with solid objects which will be bad for any gearbox.
Remove the pto shaft from the blower and then go and turn the fan by hand to see if it rotates smoothly and without any wobble. Watch the auger as you do this. Some slight bending in the auger itself is acceptable.
Last, bring something like a pipe cleaner. It is something with a fuzzy exterior and bendable so you can insert into gear box upper hole and see the condition of the oil and its level. Dirty oil of any presence of water is not good.
Dave M7040
leonz I don't have a big enough trailer to bring my machine,as far as the anchor... I didn't think that I had to put in on the ground, but I will get chains it makes sense.
dave I will try again to attach pics, it just hasn't been working for me.....01313_7NbNNnqWjBQ_1200x900.jpg00q0q_2EO9nzhuboe_1200x900.jpg
/ hanson 3 point snow blower #12
dave I will try again to attach pics, it just hasn't been working for me.....View attachment 521958View attachment 521959
That blower looks like a McKee Snowlander. McKee, a Canadian company made blowers for Kubota and others in the 1970;s and 80's and just painted them different colors.
Does it have open gears like these in place of a gearbox just behind the fan.
The three blade fan is a bit of a clue.
Regardless, that blower looks like one that will serve you well.
Dave M7040
I don't know I am still trying to set up a time to go look at it.....
/ hanson 3 point snow blower #14
Blowers today incorporate an easily added design feature which blocks off a portion of the circular fan opening to restrain the snow as it goes up the chute.
A piece of approx 1/8" steel plate bolted on is the way to do it.
This image is of a brand new blower.
This one is the one you posted photos of.
Dave M7040
/ hanson 3 point snow blower #15
Not sure if that's a McKee, it is kinda similar though. Here's my McKee Snolander 520:
/ hanson 3 point snow blower #16
Your 520 McKee is like the 720 I had but mine had double augers. Your 520 would have a gear box full of oil behind the fan.
The smaller 48" McKee's had the square chute not a round one.
The 48" McKee used open bevel gears which run with only snow for a lube and last forever,
I have some McKee manuals courtesy of "Eric the Oracle" , a member on this forum
Dave M7040
/ hanson 3 point snow blower #17
Gotcha, all great information! You're correct, gearbox full of oil behind the fan on mine. I actually have an original parts/repair manual for my 520, too. I make a point to find original parts manuals for my implements if possible, makes sourcing parts much easier!
I read somewhere that the three blade 2nd stage fan wasn't the best at removing all the snow the auger feeds it. From looking at the parts diagram and the materials it's made from, if I find it to struggle it will be easy to fabricate a new blower fan for it. I'll decide after I get some use out of it! Thanks for the informative post, Dave!
/ hanson 3 point snow blower #18
I would try first adding the triangle piece near the fan as it is easy to do. Since it is on all new snowblowers I have seen it must be an improvement.
Sometimes the triangle piece is welded on which is a real pain. Three bolts will hold it secure and be easy to remove if the fan has to come off.
Getting the fan off the gear box hub is next to impossible, at least when I had to do it after blowing concrete blocks, thus bending the fan.
The 3 blade fan will do the job as long as you control the backup speed. Its performance would have to be pretty bad to justify the oxy acetylene torch work getting things hot enough to try and pull.
Pulling with a puller is hard as there is really nothing to grab with the puller arms and getting a strong enough bolt in the fan hub for the puller to push against usually resulted in a bent grade 8 and lots of cursing.
Dave M7040
/ hanson 3 point snow blower #19
Is Hanson still in business? Does anybody have any contact info?
I saw this Toro blower on Craigslist and was wanting to talk to Hanson if possible. It looks a lot like my Acra made, Toro snow blower. They are made in the same town, So I am guessing they are the same company - One bought the other out.
Toro Groundsmaster Snowblower Attachment - farm & garden - by owner - sale
/ hanson 3 point snow blower #20
Nope, Mr. Hanson Died over a decade ago and the snovac people bought his existing drawings and any patents in force.
They have not bothered to improve them either.
2007 KENWORTH T800 CRANE TRUCK (A63569)
2007 KENWORTH T800...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
2023 J&J TRAILER (A63569)
2023 J&J TRAILER...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63118)
2012 Ford F-150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
Case 580 Super M Backhoe (A64047)
Case 580 Super M...
