First experience with Kubota Warranties in 25 years, first bad experience with Kubota
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #1
628pm
Gold Member
Centralia, Illinois
kubota f2690, 2020 Kubota BX23S, JD Gator 2018 XUV835M HVAC
I have a 2017 BX2680 with 208 hours on it. It is used to mow grass and minor other stuff around our place. Noticed earlier this year that the brake pedal would not come back to the "top". Contacted dealer they were extremely busy so I said we could do it later in the year, don't use the brake for anything anyway except for starting the tractor.
Well of course to see what happened they had to split the rear case on the tractor. The brake rotor looked like a car that had been run for 100000 miles with no brake pads. Dealer told me if the brakes are glazed it would not be under warranty. They had the service rep come in, he denied the claim saying it was operator error.
I've purchased 8 New Kubotas since the 1980's, I would think I would know not to ride the brake, especially when just mowing grass. I told the dealer that we don't even use the brakes, the ground is level. We have never hauled the tractor on a trailer until I took it in this time. So we don't use the parking brake either.
I told the dealer that it was either operator error or mechanical failure, and I know it was not operator error.
I then appealed to Kubota, took them about 6 hours to tell me that the rep reviewed the issue and the tractor and they stand by that decision. But they do value me as a customer.
Do you think they value me as a customer? I don't think so.
Never had anything bad to say about Kubota, but this has changed my mind, they are no more concerned about a customer than the tree outside my window.
For all of you mechanics out there what do you think?
Thanks
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #2
Brake glazing would be due to a dragging brake. In an around about way it is operator error. I suspect that the brake linkage was sticky, and you would push the brake pedal down to start, but due to slight corrosion or other factors, the brake didn't completely release. And over time has become worse, but since you didn't notice the brake dragging it damaged the brakes, which will appear identical to somebody that didn't release the parking brake and used the tractor. Could brakes be considered a wear item, and excluded from warranty coverage. Just thinking.
An unforseen issue, that wasn't noticed but could be caused by what may look like a maintenance failure since it wasn't caught earlier, and the sticky linkage wasn't lubed. Not saying that you did anything wrong or failed to maintain your equipment, just looking at it from a dealer standpoint how they would see it.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #3
Did you happen to get the KTAC insurance?
Brake pads are a wear item, it states that in the warranty, I did follow their recommendations for maintenance, tractor was garage kept and I blew off grass clippings after each mowing. What you stated seems reasonable, but I would call that mechanical failure not operator failure.
Thanks for your response.
Yes I had the insurance but I paid it off real quick then home owners took over. On my f2690 I bought last year I started paying it off then thought better of it. Just paying 20.00 a month now since I’m so far ahead in payments.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #6
Had a more or less similar case with a clutch that started slipping on a 2016 Mitsubishi Outlander with just 30,000 miles... Dealer/shop kept claiming it was driver/operator error even though it wasn't. Found out later, after the new clutch kit was fitted, that the previous clutch probably had air in the slave cylinder causing it to slip till it burned and started slipping a lot more.
We have been costumers for over 25 years but they simply don't care when it is something classified as "wear item".
These "wear items" in warranties just looks to me as an easy way to get their hands of the responsibilities.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #7
I'd do everything I could to put it back on the dealer.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #8
I just had warranty refused on a 1.5 year old jeep with 15k. Brake warranty is 2yr or 18k per manufacturer. They stated rust was the issue and warranty does not cover that. The slides and pins were sticky. There was no lubricant on either. They wanted 1k to fix it. 2 hours and some Sil glide and I was golden. I took pictures of the pins that had no lubricant on them and contacted the dealer and Jeep. They just gave me the Oh well treatment. They stood behind their environment and salt they use in winter as causing my issues.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #9
Funny you mentions Jeep and brakes. I got a '07 Compass that I replaced all the calipers on 2 years ago (actually 16 months ago). The front drivers side piston froze last week. Fought back and forth with the dealer about the caliper. They said it only has a 12 month warranty, and I'm lucky that it lasted that long. Mind you the factory originals lasted about 10 years...
Mind you I did the work myself -- I was just asking for a replacement caliper so I could swap it out... nooope.
It is what it is... at least with my tractor, I had great experiences with my dealer so far.
   / First experience with Kubota Warranties in 25 years, first bad experience with Kubota #10
I agree that it was most likely a mechanical failure, but unfortunately a mechanical failure that is not repaired in a timely fashion can be considered operator failure. And that is they way companies perceive a warranty issue that wasn't corrected in a timely factor. The will say it is your fault because you didn't catch the issue before it got to that point of failure.
I am a warranty service center for a lot of different brands One of the companies I work with considers the inner spool, outer spool, bump head, and bump knob as wear items and carry no warranty, Meaning you buy the trimmer one day and wear through the bump knob the next it is your problem. With that said, I have bearing failures on the end of the shaft that actually melted the plastic head, and they still won't pay for a replacement head, even though the bearing caused the head to fail.
2018 Dodge Ram 3500 (A57148)
2018 Dodge Ram...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2014 Chevrolet...
(2) 255/70R22.5 TIRES (A58374)
(2) 255/70R22.5...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
2016 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A56858)
2016 Peterbilt 579...
