   / Harbor Freight Tools that don't suck #10,491
Any any experiences with the concrete mixers? Or better option in same price range? Looking for something to mix maybe a pallet of quikcrete at a time, and and not wanting to spend a fortune. View attachment 581170
A neighbor has the larger of the two HF models, the 3.5 cf. I used it a few years ago to mix and pour several bags of quikcrete as a base for a freestanding livestock waterer. Worked very well.
   / Harbor Freight Tools that don't suck #10,492
I have the 3 ½ unit and it has been great. Done well over a pallet over the last couple years without any problems. The only bad I can say is the wheels are a little to close together so it can be tippy, and it does not dump too far away from the base. I made a little chute for the cement to slide down and attached it to the bottom of the mixer and it worked great when I needed it. Took maybe 10 minutes to make so not a big deal.
   / Harbor Freight Tools that don't suck #10,493
I have a Black & Decker lightning angle grinder that I bought at Lowe's quite some time ago, possibly in 2007? It's still holding up very well.
Aaron Z
I agree, I bought a 6amp B&D and a 6amp Skil and both held up as well as any of the Dewalts I've owned
   / Harbor Freight Tools that don't suck #10,494
Yup.... a bag at a time & it will run forever.
Two bags is a real struggle & forget three.
   / Harbor Freight Tools that don't suck #10,495
I have the 3 1/2 cuf one for about 12 years now. Probably ran at least 200 bags through it by now. It has sat outside its entire life. Still works good. Two 80# bags is definitely it's max. Two 60# easy. I've known people that have the plastic barrel ones and they're done after about 5 years outside.
   / Harbor Freight Tools that don't suck #10,496
Yep, did the same thing with the chute. Also changed out the wheels after a few near topples. Had a couple of old $5 specials from HF...fit right on and made the stance a little wider.
   / Harbor Freight Tools that don't suck #10,497
Yep.
   / Harbor Freight Tools that don't suck #10,498
Also have strapped it to my forks so I could get it up to a project and dump in place.
As other have said 2 60lbs bags is the most you want at one time but for the price you can't beat it!
   / Harbor Freight Tools that don't suck #10,499
I have the 3.5 CF one. It is limited, 2 sacks of 80# mix overloads it. For post holes I mix 1 sack of pre-mix with 1/2 sack pea grave land it is all it can handle. Frame work is pretty light weight, definitely not a production item. I have it just to save renting one every time I need to mix a few sacks. more than 1/2 yard I will get ready mix. My days of mixing in a wheelbarrow are over. The solid tier wheels do not work well on rough ground. I replaced with HF pneumatic wheels and devised an attachment to allow moving around with my BX FEL. A previous post shows the pictures of these mod.
Ron
Ron
Toro (A56857)
Toro (A56857)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
Informational Lot - Financing (A56438)
Informational Lot...
