What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #231
Very nice!
   / What did you do on or to your LS Tractor today? #232
Front axle oil change for first 50 hour service....at 65 hours. Oooops. LoL
   / What did you do on or to your LS Tractor today? #233
Decided to take out a stump I left from the other day. Took this pic from about 75-yds. away with my cell phone. The green at the bottom is a backdoor light casting on the grass.
Those lights are awesome.
   / What did you do on or to your LS Tractor today? #234
yours said to change the oil on the front axle? My XG 3025 just says to check the front axle oil, which I did have to top it off. Mine doesn't say to 'replace' until the 500 hour mark. I won't wait that long, just like I'll change my engine oil every spring, because even sitting inside a closed garage, there will be some condensation inside the engine over the winter
   / What did you do on or to your LS Tractor today? #235
Yea it was probably too early...but there were lots of shiny bits that flowed out of the drain plugs. It was cheap maintenance and easy to do.
I have the XG3140 and the manual says the same as yours. Check at 50 hrs. Replace at 500 hrs.
I'm unsure what the front axle oil level should be. The 'oil gauge' described in the manual is just a threaded plug for a cap....no type of dipstick for a level. So I filled with 7 quarts and I figure thats close to 1.7 gallons.
   / What did you do on or to your LS Tractor today? #236
Did a combination of snow blowing and plowing snow for about 4 hours this morning. We got just over a foot.
   / What did you do on or to your LS Tractor today? #237
yeah I've questioned that front axle 'gauge' myself. if you emptied it, your manual tells what the capacity is, mine says 1.7 gallons
   / What did you do on or to your LS Tractor today? #238
On my xg3025 the plastic plug is a vent. The dipstick is on the metal cap on the other side of the front axle.
   / What did you do on or to your LS Tractor today? #239
that's the first time I've seen or heard that, I appreciate that!
Dug up a couple of trees. Then dug holes in another spot to plant them again. Slid around in the mud a bit.
Digging I can do fairly well now. Smoothing over the holes is another matter. Can't quite get that part down without using a shovel and rake.
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
NEW Wolverine 84in High Capacity Pusher (A59000)
NEW Wolverine 84in...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
