Torpedo/Salamander heater best practices?
   / Torpedo/Salamander heater best practices? #21
Just a note of caution with the kerosene heaters. If it doesn't light right away and you have to re-try it several times, when it does start it will shoot out a flame a foot or more.
When I was a lad, I almost burned down a new house under construction that had straw all over the concrete floor that they were pouring in the winter. Had to go home and change my pants.
   / Torpedo/Salamander heater best practices? #22
When I was a lad, I almost burned down a new house under construction that has straw all over the concrete floor that they were pouring in the winter. Had to go home and change my pants.
I recall an incident in our grocery store several years ago where the walk in freezer failed and had to be thawed for service. The guy used one of those heaters to speed the process but got too close wearing polyester pants. It could have a disaster (that stuff "melts") but fortunately wasn't...he escaped unhurt but we had to find some pants for him.
   / Torpedo/Salamander heater best practices? #23
Sometimes forced-air diesel/kero heaters need just a bit of adjustment to the fuel metering to make them burn clean and stay burning consistently. Instructions are usually in the manual. Clogged combustion air filters will also cause them to burn poorly or flameout.
Mine didn't permit any adjustments. However I have to clean the intake air filter often (was my wood shop so sawdust was everywhere). I also had to clean the electronic eye (safety device to detect flame) from time to time.
   / Torpedo/Salamander heater best practices? #24
How much did it cost?
It's on sale for a day or 2 yet. sale price is $229. I had a 10% off coupon and the total including tax was $219. There was none in stock at the stores in my area and I had to ordered it on line and shipped to the store, there was no freight charge. Should be here sometime next week.
Following up on this-- thinking of buying one of these units and wondering if anyone has experience with this particular model? Seems to have some advantages over traditional torpedo type heaters-- especially with noise:
Tractor Supply Master Heater
It's not true of all but most are designed that way today. My understanding is that you could burn diesel in any of them but the older ones would smoke sometimes if you did. Mine is clearly labeled diesel/kerosene.
   / Torpedo/Salamander heater best practices? #26
The one I got was bad out of the box. It worked, made good heat and was not very noisy. But, it leaked fuel out around the burner unit. So either there was a problem with the burner housing, nozzle or my thinking fuel pump was supplying too much pressure. Boxed it up and returned it.
Stopped at Lowes since TSC doesn't stock these heater in stores and got a Remington Heater exact same thing as the Master Heater, only Lowes was alot more money. Unboxed the Remington and fired it up, then found that the cooling fan under the burn chamber wasn't running. Thought here we go again, removed the back cover and found the plug for the fan was not connected to the circuit board. Plugged the fan in and fired it up. So far it works like a charm, good heat output and very little fumes on start up and shut down. I'm running it on cheap Kerosene, not K1 stuff which is $3.80/gal around here. If it keeps working good I'm going to mix 50/50 Off road diesel and Kerosene and see how it works. I like the way the heaters work, there small, not to heavy and not noisy like a torpedo heater. also not hard to dis-assemble the components.
   / Torpedo/Salamander heater best practices? #27
Just my two cents....
I am a big fan of radiant heat and suggest that some form of it would be what you would like to have for a workshop. I agree that hot water radiant heat installed in the slab would be the ultimate way to go. It would not have to be all that expensive either if you are going to install a slap anyway. You can heat the water using a more or less conventional electric water heater too. A tankless type would be a good bet. You could also create an array of tubing external to the slab something like a large towel warming radiant heater.
If radiant heat in the floor is not an option then you could try some of the following:
If you do need to stay with electric and don't mind moving the heater around to the area you are working I think the following type of electric radiant heater would be great:
Best Garage Heaters (Reviewed & Tested / Nov. 218) - Buyer’s Guide
In looking for the type of electric radiant heater I was thinking of I stumbled across the following electric garage heater that seems to have received good reviews and could be just the ticket:
homedepot.com enter sku# 344117
If you want to go the route that would be more typical in comercial garages and shops you might take a look at the following type of propane fired radiant heater. You would have to make sure you had enough ventilation but I think all you would have to do for that would be to pick a ventilation fan with the coresponding amount of CFM and make sure it is turned on when you use the heater.
Grainger Industrial Supply: Heater,Infrared 3E460
Grainger does have a lot of other types of heaters too by the way.
Just some suggestions and one good vide, that I hope will help.
   / Torpedo/Salamander heater best practices? #28
Need to do some assembly work in our unheated garage this winter. It's uninsulated and 28x30 feet with 10 foot ceilings. Open stairway in back going up to an enclosed, heated studio.
Given it will be an off/on situation it seems a forced air kero heater is the most practical way to go. Would appreciate any advice or precautions to take from others with a similar situation?
Propane ok. I'd avoid kerosene/diesel heaters as the combustion fumes are really bad for your health - especially if you plan on being in those spaces to work. Watch for CO/CO2 leakage into your studio. I'd install CO detectors in both places.
   / Torpedo/Salamander heater best practices? #29
You do realize that this is a two year old thread?
   / Torpedo/Salamander heater best practices? #30
I always wanted one of these and finally bought a bunch at an auction.
It did melt my snow pants and burst a favourite air hose, where I didn't even think it was making heat!
I want to work on something in my drive shed today, but this thing is kind of overkill. I would like to see about getting an electric quartz patio style heater.
I also have a kerosene salamander heater, but as with the heater in the picture, they are too noisy to enjoy working close by. Plus the salamander likes to drink a lot of very expensive kerosene! The big radiant heater runs on diesel and does not smell.
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A54865)
2007 Ford Crown...
