Planted oaks today.., TSC county line auger is awesome...
   / Planted oaks today.., TSC county line auger is awesome... #1
Cavjock22
Seabrook, TX
Kubota M6060, Bushhog 3210, Deere offset disk, Deere B drill, forks, bucket
Planted Oaks..
Auger is the only way to do it..
   / Planted oaks today.., TSC county line auger is awesome... #2
Thats what we did last week-end. Planted 11 trees and 5 shrubs. PHD makes it so much easier than using a shovel ! I used a 9" auger but going to get a 12" auger for bigger holes. That looks like some rocky soil !! Nice job....
   / Planted oaks today.., TSC county line auger is awesome... #3
Does that PHD have a reverse gear on it? I'm thinking if I got one, I'd want to be able to back it out under power, just in case I ever did the proverbial corkscrew-into-the-ground thing.
Since the auger works PTO there is no reverse..
The only way to have reverse would get a hydraulic setup.. Considerably much more expensive than PTO auger..
   / Planted oaks today.., TSC county line auger is awesome... #5
Perhaps we should call you Admiral Collingwood. It seems 200 years ago today Collingwood was the first to fire a shot in The Battle of Trafalgar. He was also famous for in his spare time he used to go around and set acorns. It apparently took about 200 oaks to make one ship like Nelsons Victory. Collingwood had no idea that by the time his oaks had grown, they were to be making ships out of steel.
   / Planted oaks today.., TSC county line auger is awesome... #6
No PTO driven one has a reverse. Or at least none that I have seen. Only hydraulic driven ones can reverse.
   / Planted oaks today.., TSC county line auger is awesome... #7
What gets me is that some people have dirt under their feet instead of rock. :(
   / Planted oaks today.., TSC county line auger is awesome... #8
Nice. I've become a huge fan of the Country Line auger after trying three other brands with poor results. For the money, there is no better deal out there that I'm aware of for such an aggressive digging machine!!!
After reading all the positive reviews and as little as I will be using it; I figured it was a no brained.,
   / Planted oaks today.., TSC county line auger is awesome... #10
big pipe wrench, maybe 1/2 turn to 1 turn and it will usually lift out of the hole.
MCCORMICK T110 MAX TRACTOR (A57192)
MCCORMICK T110 MAX...
2016 Fiat 500X (A56859)
2016 Fiat 500X...
2012 CATERPILLAR 303.5D CR EXCAVATOR (A52707)
2012 CATERPILLAR...
UNUSED JCT 84" HYD DOZER BLADES (A57193)
UNUSED JCT 84" HYD...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
