Tractor Sizing TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #31
That, and SO MUCH CAPSLOCK :eek:
So many cap locks makes me upset and depressed and probably need medication to overcome this caps lock Crazy ness, god help us.. Some of the childish posts I read are quite silly out of grown men..
ATSAH: I hope you have low deductible, comprehensive health insurance including a pharmacy benefit.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #33
there is no such thing since the gov't entered the health care industry
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #34
It's a tradeoff. In my case, I bought a 1600 or so pound CUT, one notch up from a SCUT because I wanted to cut the grass with it. Since then I've bought a garden tractor to cut the grass, and I no longer have a pressing need for a light tractor. I do some gravel work on a 1/4 mile right of way, and I clear the snow on it in winter. Most of the snow work allows be to work on the downgrade, so it does a good job. I can do good work with a five foot box blade as long as I don't try to pull too much material up hill. Now, I'm looking for a slightly heavier, more powerful tractor, around 40 hp, for a stronger / larger loader and more PTO power to run a chipper/shredder. I would also use the stronger loader to try to pop out some rocks from the grass that the smaller tractor can't budge. Thing is, if you are going to cut grass on a regular basis, I don't think a 4000 lb. or bigger tractor makes a lot of sense. Ok to cut a field a few times a year, but not for the lawn, at least, not here where drainage is a problem and climate change is turning us into monsoon summers.
The one thing I would suggest to people is that if you do buy a small tractor and want to go bigger, you'll likely be looking to upgrade your implements as well, which can be costly. For example, my 5 foot cheapie box blade is fine for me. But I've read that the same brand, when used on more powerful tractors in a 6 foot model, is prone to bending. If I upgrade my tractor, i'll likely be using the 5 footer and not be able to cover the wheels, which could be a problem. Not sure yet. Same with mowers, etc. I tend to be looking at heavier tractors now for the simple reason that the heavier tractors in a given horsepower tend to have stronger loaders. On the other hand, very light tractors like mine or the Kubota B Series could be perfectly fine for someone who is going to be cutting grass or a field. They would also have the power to run a pretty serious snow thrower, though you'll want chains for sure. If you're going to get into serious dirt work, then the weight obviously becomes more important.
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #35
I’m good, my part ‘D’ will cover anything I need, even those CAPITALIZED pills..
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #36
I am not sure what the real problem with CAPS. In 1970, computer keypuches did not have Caps. Printers did not print them. It had to do with the speed of the printers.(I will save that for a computer history class later). My boss wants everything in Caps, it is easier to read. Maybe some people are helping by making it easier to read.
I think the biggest problem with this thread is the title. TRACTOR WEIGHT as one of the CRITERION IN TRACTOR SELECTION
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #37
I think many of us would be happy if the capitalized letters in this thread are the biggest problem we all face today..
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #38
CAPS has traditionally been viewed as YELLING. ;)
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #39
I didn't hear any yelling when he opened this thread but he is 1600 miles away, maybe they heard Jeff in GA IDK..:D
   / TRACTOR WEIGHT as a SINGLE CRITERION IN TRACTOR SELECTION #40
Not for people in computers for over 45 years. That is another thread. I only yell because I am hard of hearing.
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
John Deere 1025R (A53317)
John Deere 1025R...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2025 Ligchine Spiderscreed Concrete Screed (A55851)
2025 Ligchine...
2018 KUBOTA SVL75-2 SKID STEER (A52707)
2018 KUBOTA...
2001 John Deere 4600 (A53317)
2001 John Deere...
