Brand new L2501 started making a nasty noise at 6 hours
   / Brand new L2501 started making a nasty noise at 6 hours #1
auroraproject
Member
BX25
I received my brand new L2501 the Friday before last. It came with a pile of implements and I've been testing each out. I put about an hour on it with the forks, moving stuff around. Another hour pulling my driveway back up onto the hill with a BB2560 in Low/4wd. Some digging with the bucket and using the hydraulic auger to make holes for trees. A couple hours bush hogging. It went straight to work, varying RPMs and nothing over 2200 and trying to not lug it too bad.
At 6.6 hours today, I was moving a pile of dirt around. At around 1800rpm, I pushed into the pile, lifted, then was backing up and suddenly this clacking noise started. I shut down immediately and checked under the machine because it sounded like a branch was in a fan. There wasn't anything and there was plenty of clearance. So I started it back up and the sound was there like it is in the video, a bit subdued from what it was at first. It was loud enough in the beginning to get my gf to come running from across the yard to ask wtf was going on.
I dropped all the implements and parked it somewhere about 20' away where it could get on a trailer and shut it off again. I'm contacting the dealer to have them come pick it up, but I'm trying to figure out what's going on with it.
- Engine was warmed up and had already been running about 30 minutes.
- There are no smells or smoke.
- It hasn't been run more than a minute since this happened, so I can't say if there's a loss of power.
- It moved normally to where it is now parked, and the hydraulics worked file to operate the steering, hst, loader, and 3pt hitch to ditch the implements and park it.
- There is engine oil on the dipstick, though it is a little grayer than I'd like to see.
- I didn't drain any oil from the pan because I didn't want to interfere with the warranty, the bolts are still painted over.
- The fuel bowl is clean, no water in the bottom. Still has the dealer's fuel in it. I bled the fuel system per the manual.
- The sound is directly proportional to the engine RPM.
So what do you all think is the cause here?
Bad timing? Stuck injector? Rod bearing failing?
I'm reaching out to the dealer to have them take care of it. Hopefully it's not something catastrophic.
   / Brand new L2501 started making a nasty noise at 6 hours #2
Have you opened the hood and looked for anything obvious while it's running? Like something hitting the fan or something that isn't tightened?
Would've been a better video if the hood was opened and during the day so we could see what was going on.
   / Brand new L2501 started making a nasty noise at 6 hours #3
Sounds like something came loose. Open the hood and try to move things that shouldn't move.
I had the hood open when I was looking for a stick in the fan, and again after I dumped the implements. I didn't see anything moving that didn't usually move. It's brand new, very clean in there.
   / Brand new L2501 started making a nasty noise at 6 hours #5
Not familiar with the machine .... does it have a fan on the Hydro Transaxle? If so, did you check that one for obstructions?
   / Brand new L2501 started making a nasty noise at 6 hours #6
If you read the post, that's the first thing the OP looked at.
   / Brand new L2501 started making a nasty noise at 6 hours #7
Its brand new - let the dealer tell you what it was - after he fixes it and returns it.
   / Brand new L2501 started making a nasty noise at 6 hours #9
Something stuck in a fan would make a noise at many times engine speed. This noise is at engine speed. Unfortunately it's likely to be serious engine damage.
This is what I was thinking.
Also the plan.
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
UNUSED JCT 84" SNOW PUSHER (A58376)
UNUSED JCT 84"...
2019 TAKEUCHI TL10V2 SKID STEER (A52709)
2019 TAKEUCHI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Yamaha YRDEX4 Electric Cart (A56859)
2014 Yamaha YRDEX4...
2000 JCB 532 7,000LB Rough Terrain Telehandler (A56857)
2000 JCB 532...
