Planters Taylor Pasture Dream No-Till Drill
   / Taylor Pasture Dream No-Till Drill #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
Got a nice Taylor Pasture Dream drill from CL and used it to plant sunflower/corn for Doves this weekend for the first time. It has some issues (really, it's only about 60 years old!) that I need some advice on.
1. The shut off mechanism that opens and closes the seed/fertilizer plate is worn at the pivot (probably egg shaped) and does not push the bar far enough to open and close the drop holes fully. It seems to be cast steel. Can it be machined out and sleeved to remove the 'slop'?
2. Should the seed boots be lower than the front coulters?
3. Considering replacing the mechanical shut off with a small Hydraulic cylinder to operate the seed gates. This keeps the seed/fertilizer from falling while the unit is raised while turning.
Anybody got one of these units and has to modify or repair? There are no parts available from Taylor.
Thanks
151 looks and no comments??
come on!! Somebody got to have an opinion!!
   / Taylor Pasture Dream No-Till Drill #3
Hello.....just picked up this thread while searching for Taylor or midland pasture dream....I have 3...1 Taylor and 2 midlands...my brother has a midland. There are some wear parts available...plow points and seals from RH machine...I worked with them to produce the seal which is the bat wing at the rear of the plow boot. I am working to get other parts to be developed for these machines. I can share information for set up for planting...colters... plow boots...shut off linkage
   / Taylor Pasture Dream No-Till Drill #4
Thanks
Don't own a Taylor. But I have restored several old Minneapolis Moline P3-6 grain drills (10 ft wide, 20 drops, single disc openers).
And I have replaced the rope-actuated trip mechanism that raises the openers with a double action hydraulic cylinder.
I like the simple design of your drill.
I should think that the coulters should be lower than the seed boots--just an opinion. I assume the coulters and/or boots are adjustable in height.
Don't see why your problem with the cast steel part can't be machined and sleeved unless there's a problem in removing the part so work can be done on it. Like I said, I don't have any experience with your type of drill. I have welded cast iron and steel successfully if that's any use to you.
Good luck.
   / Taylor Pasture Dream No-Till Drill #5
Did you ever find parts for the planter? I just picked up a Pasture Dream and I need a few replacement parts for mine. I need to replace all of the coulters and am having trouble finding them? Any advice would help. Thanks.
   / Taylor Pasture Dream No-Till Drill #6
Could you please contact me. I have just gotten a Midland unit and it is in fairly rough condition. Coulter cutters need replacing. would like to get information on the units, maybe an operator's manual. Haven't looked at the plow points, but probably needs them. Noted the reference to RH Machine. Any information would be greatly appreciated. I plan to restore and use the unit.
   / Taylor Pasture Dream No-Till Drill #7
Shoes will need to be fabricated. The Coulter are available . You just have to verify your bolt pattern . They are simple implements but work really well. Mine is hooked up right now waiting on some moisture to plant millet.
   / Taylor Pasture Dream No-Till Drill #8
Having trouble finding coulters. Do you know a supplier? Mine are 12" x 1/4" thick, 4 bolt (5" bolt pattern) and 2" center. They are flat on one side and beveled on the other. Need 6.
   / Taylor Pasture Dream No-Till Drill #9
I just took one into my deere dealer and matched one close. Mine are wavy , A little bigger Coulter wont hurt you may just have to adjust the depth on the bracket.
Send me an email and I will forward you the operators manual. I have sent it to probably 30 folks over the last few years when i posted my email on another thread on here.
dmatthews@gulfeaglesupply.com
   / Taylor Pasture Dream No-Till Drill #10
Hello pasture dream I recently bought a midland no till drill but I'm having issues with it. I bought to plant food plots but as I'm No tilling the plow bloods are collecting so much grass an dirt it stops the coulters and bogs down my tractor it has been sprayed with herbicide and is dead but it seems like coulters are just running it over and isn't cutting it an the plow points are collecting it?
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
CATERPILLAR 259D3 SKID STEER (A52707)
CATERPILLAR 259D3...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
2004 Mack CV713 Granite Fuel and Lube Truck (A55852)
2004 Mack CV713...
