More trouble for the Duck Boat.
   / More trouble for the Duck Boat. #41
I believe you'll find that getting enough water in the bilge of a duck boat to snuff out the engine by submerging the distributor or air intake with 30 people on board would only happen after buoyancy is lost and the boat is already headed under... The bilge pumps on these boats are engine driven, and capable of moving massive amounts of water when they're working properly...
Duck boats are often operated on land with the the "hood" slightly open to vent the engine compartment, which is in front of the driver. Watching the video, it's obvious that every time the nose goes under, the boat gets lower in the water... I wonder if this one had the hood left open while they were on the water...
As larger waves come over the nose, the open hood would act like a water scoop. Probably not much concern with one or two waves, but add that water to any leaking seals, and then keep dumping water in through the hood, and you can probably overwhelm the bilge pump pretty quickly...
The lower the nose gets, the more water comes in... It appears to finally quit running just as the camera goes off it and the person recording says it's going under, which makes sense, since the nose at that point is no longer emerging from the water.
What baffles me is that there was obviously water coming in while they were underway. A bilge alarm sounds because the bilge pump isn't keeping up. Having enough water to set off the alarm in a boat with limited freeboard is always cause for action, and yet they're still well off shore minutes after the alarms have sounded.
That makes no sense to me, as both ducks were obviously experiencing conditions bad enough to cause me concern just watching. I have to imagine it felt even worse inside the boat, especially with water lapping up the the outside of the windows and spilling in... Seems like the captain would have made for shore immediately after the first alarm, with conditions as they were. I know hindsight is everything, but my philosophy is that any port will do in a storm. Get. Off. The. Water.
I suppose we'll never know what really went on, but it is certain that mistakes were made, and not necessarily just by the captain. Sending the boat out in the first place to race the weather was not smart... The captain not recognizing that the boat needed to get off the water quickly, not getting people into life jackets and not getting the side windows popped quickly all contributed to this tragedy...
It's a terrible shame that so many lives were lost, but hindsight won't bring them back. We can only learn from these mistakes and avoid repeating them in the future. Hopefully the investigation will eventually reveal what exactly went wrong with this boat that seemingly wasn't a problem for the other boat. Hopefully we can be sure not to make that mistake again...
   / More trouble for the Duck Boat. #42
Didn't any of you read that on this model, the exhaust is in the front bow of the machine. Water can go into the exhaust and kill the engine if waves get high enough. I think I read that in the safety report by the inspector that the company hired before they bought the business. He warned them of that. So if the engine dies, the bilge dies, the boat takes on more water and down she goes.
   / More trouble for the Duck Boat. #43
Duck boat inspector found boats wouldn't meet federal standard | FOX2now.com
Bruce
   / More trouble for the Duck Boat. #44
A diesel Engine with Intake and Exhaust snorkel would probably work. Much more economical too. I guess, those people would still be alive.
   / More trouble for the Duck Boat. #45
We can guess whatever we want. The best thing to do is learn from the incident and correct anything that can be corrected and wait for the next tragedy to learn again. That's how we learn.
The sad thing is these were known issues that were ignored.
I'd say take the tops off and require life preservers be worn at all times.
Makes you wonder why it's taking so long for seatbelts to be required on school busses.
   / More trouble for the Duck Boat. #47
Makes you wonder why it's taking so long for seatbelts to be required on school buses
There seems to be no agreement on the seatbelt issue on school buses. Cost seems to get in the way.
I remember some of the military cargo planes in the '70's had all the seats facing the rear of the plane. It seems like a logical and economical way to offer some protection to bus riders.
   / More trouble for the Duck Boat. #48
Much transportation has found the safety merit in that. But ah, people for the most part don't like to sit facing the wrong way.
Many inboard boats have their exhaust below the water line. They don't sink on account of it.
   / More trouble for the Duck Boat. #49
I'm still amazed that the boat was out there for 7 MINUTES from the time whitecaps appeared... and nobody thought to put on life jackets. I just can't get that through my head.
   / More trouble for the Duck Boat. #50
Maybe it's difficult or near impossible to get life jackets put on in a tight space, panic stricken passengers and rough seas.
Quick Attach EZ Axe Skid Steer Tree Shear (A52128)
Quick Attach EZ...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
2016 POLARIS RANGER ETX EFI 00HC RTV (A51243)
2016 POLARIS...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
