Oil & Fuel Safe to use diesel from a pickup transfer tank in a new tractor?
   / Safe to use diesel from a pickup transfer tank in a new tractor? #11
How do you think big operations get fuel in their equipment?
   / Safe to use diesel from a pickup transfer tank in a new tractor? #12
4570, depend on the operation. at work we have the oil guy fill our machines right off the delivery truck. he drives through the pit and fuels everything twice a week.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #13
Even so, you are still getting fuel from a transfer tank. The delivery guy fills his truck from the big storage tanks at the bulk retailer's location. These are in turned filled from tanker trucks that are filled at the refinery. So by the time you get it from the bulk retailer, it has already been thru at least 2 transfer tankers.
I store my fuel in a bulk 275 gallon plastic TOTE tank and transfer it to my 100 gallon steel tank as needed. From there it is pumped via a Filrite pump with a 10 micron filter straight into which ever vehicle needs it. I have never had any issues with algae, water or trash in the fuel.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #14
And since driving the tractor to the fuel station isn’t a likely option then you’re going to use a 5 gallon can.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #16
Nope. I use 55 gallon steel drums that I've had for maybe 25 years. Have the Goldenrod water absorbing filter right after the pump, where the hose connects. I keep them sealed and buy from a dealer I know has high turnover. I use Power Services snake oils to ensure the storage tanks and injectors stay clean.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #17
Isn't your barrel a transfer tank?
   / Safe to use diesel from a pickup transfer tank in a new tractor? #18
It all comes down to the history of your fuel supply. If you have good filtering and no water issues, go for it. If you've had problems with stuff growing in your fuel or dirt/rust, then, fix it before using the fuel.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #19
Here's the question posted: "Would you guys have any concerns fueling from fuel in a pickup truck transfer tank?"
To that my answer is "Nope". I then explain what my "transfer tank(s)" consist of in case somebody else likes the idea and has or can get the resources....or pay the big bucks for the commercially made tank.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #20
So your barrel isn't a transfer tank?
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2014 Chevrolet Tahoe 4x4 SUV (A55853)
2014 Chevrolet...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
2014 Ford Fusion (A56859)
2014 Ford Fusion...
2004 Yamaha Golf Cart (A55853)
2004 Yamaha Golf...
3pt 4' Rotary Tiller (A56469)
3pt 4' Rotary...
