   / Harbor Freight Tools that don't suck #9,321
Go check out a real Echo Dealer. In my experience Home Depot overprices their Echo Equipment.
ECHO - Outdoors - The Home Depot
Compare to Echo MSRP.
Tree Pruners, Long Reach Pole Pruners, Extended Reach Pruners | ECHO USA
Thank you. His is not an extended reach and that's fine with me since I'm pruning bottom branches and just want to reach in without getting ripped apart by branches. I never prune high and there are no trees here other than what I planted. All farmed.
   / Harbor Freight Tools that don't suck #9,322
It’s probably not a $500 pole saw then. Like I said, you might want to visit a real Echo Dealer.
If you don’t need the reach, have you considered the Lynxx battery pole saw. Much lighter.
   / Harbor Freight Tools that don't suck #9,323
Was one factor in finally pulling the trigger on the tractor. Have definitely been filling in the holes on my tool collection.....have bought enough so I don't need to buy anything for quite a while.
Of course, it may not actually happen, as a lot of this talk has turned out to be bluster.
Good excuse to buy tools/equipment in any case. :)
   / Harbor Freight Tools that don't suck #9,324
Do any of you have experience with the HF Lynxx 40 volt pole saw?
4V Lithium Cordless Pole Saw
I致e got an Echo pole saw that extends up to 16 but, I知 thinking the HF saw would be good for branches just above the reach of a chain saw, and way lighter too.
Can you use the 20% coupons on the Lynxx tools and batteries?
Have used one for over year . My overall rating: Excellent.
Battery goes seemingly forever and has a rapid recharge.
Cannot use the standard 20% off coupons. Wait until they are on sale or spend the extra $$. They are worth it.
   / Harbor Freight Tools that don't suck #9,325
It痴 probably not a $500 pole saw then. Like I said, you might want to visit a real Echo Dealer.
If you don稚 need the reach, have you considered the Lynxx battery pole saw. Much lighter.
I think it's this one PPF-2620 $480 retail.
It will do exactly what I want. As mentioned, my plan is to use for the task and then re-sell it. It's better than renting. I would be tempted to keep it but don't understand how these saws can be durable and long term dependable. Then again, I've never used one.
You seem to know a lot about them so I would welcome any testimonial commentary or opinions or anything. I know zero about them.
   / Harbor Freight Tools that don't suck #9,326
I have been thinking about getting an air compressor and some air tools. I have never worked with an air compressor. I need a way to get the mower blades off of my deck, and decided now was the time. My budget is pretty limited right now and this Air Tool Kit from Northern Tool looked to be decent and the reviews are positive. The impact wrench says it needs 5 CFM. The Harbor Freight 21 gallon compressor is on sale for $145 and claims 4.7 CFM @ 90 PSI. Is it any good and will it run the impact wrench?
   / Harbor Freight Tools that don't suck #9,327
I’ve had mine for several years and it always starts on 1st or 2nd pull. All my 2-cycle tools are Echo.
   / Harbor Freight Tools that don't suck #9,328
Drove into Houston, actually Katy, this morning and dropped by HF to investigate their Lynxx 40 volt tools.
Used the coupon from PA to get the 40 volt polesaw for $139.
I found a coupon to buy the Lynxx 40 Volt Blower for $119.
4V Lithium Cordless Blower
   / Harbor Freight Tools that don't suck #9,329
Way to go!
There are also these- [which I didn't think to post because you were asking specifically after the Pole saw]:
Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - LYNXX 40 VOLT LITHIUM 14" CORDLESS CHAIN SAW
Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - $20 OFF ANY LYNXX TOOL
and you already got this one:
Harbor Freight Tools Coupon Database - Free coupons, 25 percent off coupons, toolbox coupons - LYNXX 40 VOLT LITHIUM CORDLESS BRUSHLESS BLOWER
   / Harbor Freight Tools that don't suck #9,330
The pole saw was not in stock at my local store or one close by. Ordered pole saw and blower online. $6.99 shipping and used the above coupons. Not sure how long it will take to ship.
2006 JCB 520 Telehandler (A59213)
2006 JCB 520...
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
