Oil & Fuel Safe to use diesel from a pickup transfer tank in a new tractor?
   / Safe to use diesel from a pickup transfer tank in a new tractor? #1
troverman
Gold Member
NH
Kubota MX6000 Cab
Hi folks,
I have a couple of older tractors with indirect, mechanical injection. Just bought a new tractor with common-rail direct injection. In the past, I've used my 60-gallon transfer tank and pump in the bed of my pickup to fuel up the tractors when they are in the field. That tank has a Fill-Rite "Hydrosorb" filter on it but who knows how effective it might be. I've never had issues running my two IDI tractors off fuel from this tank. However, a new tractor with common rail injection uses much higher pressures and it much more susceptible to impurities in the fuel, such as water.
Would you guys have any concerns fueling from fuel in a pickup truck transfer tank?
Thanks in advance.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #2
Just make sure it's got "lubricity" and no bugs.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #3
Might be a cheap insurance policy to change the filter on the transfer tank you have if you don’t know it’s status or how good a filter is on there. Otherwise it’s all good what small amount of junk gets in your tractor tank should be caught by the filter on your tractor.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #4
I have seen some NASTY stuff coming from transfer tanks. I would pump some in a clear container to have a look at it. If it is milky, don't use it. Then, I would poor the fuel through a white cloth to see how dirty it is. I run all my diesel through a fine paint filter in my funnel and I only use 5gal plastic jugs. Yes, the filter does pick up some debris.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #5
Don't the new tractors use On Road ultra-low sulfur diesel (ULSD)?
   / Safe to use diesel from a pickup transfer tank in a new tractor? #6
On Road and Off Road is the same, the off road is dyed red. Don't get caught will the red dyed fuel in a on the road vehicle fuel tank. Big fine for using off road in a highway vehicle since there is no road tax on the dyed fuel.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #7
All my tractor fuel is transferred using my bed tank.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #8
I view my transfer tank as an additional opportunity to run the fuel through a filter. In my case, a 10u water block filter.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #9
Same here. All of my diesel equipment including my diesel pickup is filled from my transfer tank. (I don’t use off road). I trust my transfer tank and filter setup since I regularly maintain them.
   / Safe to use diesel from a pickup transfer tank in a new tractor? #10
100 bucks says your transfer tank, if properly cared for, is cleaner than the tanks at the service station.
1611 (A57192)
1611 (A57192)
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
(INOP) 2016 FORD F150 XL SINGLE CAB TRUCK (A51406)
(INOP) 2016 FORD...
Kubota L3130 (A53317)
