Does LS have the highest rated GEL lifting capacity?
   / Does LS have the highest rated GEL lifting capacity? #1
strantor
Brazoria co., TX
LS XR4140H
Does LS have the highest rated FEL lifting capacity?
I bought an LS XR4140 a month ago because, in the same price range, it was rated to lift 1,000+lbs more than Mahindra or Kubota with the front end loader. I planned to use it almost exclusively as an all terrain forklift, so based mainly on the FEL capacity, I bought it. It was a hurried emergency purchase so I didn't dig much deeper or do much more research than driving to my closest 3 tractor dealerships. I'm happy with the tractor and I wonder if I'm doing myself a disservice by asking this question, but just want to make sure I have my facts straight before I go bragging to my friends... is there any other tractor for <30k with FEL installed, which is rated for >2,700lbs on the FEL?
   / Does LS have the highest rated GEL lifting capacity? #2
New Holland Workmaster series with the 621 FEL is rated at 3550 pounds at the pins at full height at 10 feet. At 800 mm at full height it's 2200 pounds. 800 mm is 31 inches out. At the time I purchased mine 2-1/2 years ago you could get one for 25 to 26 thousand. The FEL will do that.
Is that a 4wd tractor? A friend tried to steer me toward New Holland but I was immediately turned off because the closest dealer is 135mi from me. Now that I think about it though, with the minimal amount of hours I'll be putting on it, the dealer distance shouldn't have been as big of a factor as I made it.
   / Does LS have the highest rated GEL lifting capacity? #4
Yes...4WD and weighs 5K pounds... With loaded rears it was north of 6K pounds...
   / Does LS have the highest rated GEL lifting capacity? #5
Nothing to brag about really. There are many tractors in the 40HP range that can lift 2700 lb. or close to it. Turbys NH is close. What counts is how high they can lift and LS has one of the lowest lift heights of all. Here's the specs for your LS LL4104 loader.
LL4104
Front End Loader 72” Bucket Size
Bucker Size (in): 72
Maximum Lift height (in): 96.3
Clearance with Attachment Dump (in): 63
Reach at Maximum Height (in): 9.0
Maximum Dump Angle (deg.) 65
Maximum Rollback Angle (deg.): 34
Digging Depth (in): 4.3
Overall Height in Carry Position (in): 49.2
Lift Capacity(@ Pivot pin) (lbs.) 2,713
Breakout Force(@ Pivot pin) (lbs.): 3,802
Well shoot. I'll just try forget I ever asked, but make a mental note not to brag on it.
   / Does LS have the highest rated GEL lifting capacity? #7
Unfortunately, those numbers are inflated and not very accurate when you fairly compare the specs to other machines. I owned 2 LS machines with that loader. Nice machines.
Before I switched to Massey, I thought the LS loader claims were really impressive. But then in real world trials, my Massey loader (similar sized HST CUT machine) blows the LS loader out of the water.
   / Does LS have the highest rated GEL lifting capacity? #8
EDIT: autocorrect helped me screw up the thread title and I can't change it.
If you GO ADVANCED title can be edited for about an hour.
Thanks for the tip! It actually works for more than an hour. I just did it, 24hrs later.
PALLET OF MISC PUMPS (A54757)
PALLET OF MISC...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2018 Ford Fusion Sedan (A53424)
2018 Ford Fusion...
Front End Loader Joystick and Pump Sprayer (A54865)
Front End Loader...
