Can you negotiate the cost of a building
   / Can you negotiate the cost of a building #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I am talking with a steel building manufacturer. I assume they do, but can you negotiate the cost of the building. Not talking labor, just the physical metal? If so, what is a good percentage.
Lets say the quote I am getting has the building at 31K (which it is). My problem is I am not finding other people who use this system to build in (which I probably should).
   / Can you negotiate the cost of a building #2
I am not finding other people who use this system to build in.
I have no idea what that means.
I negotiated the price on my steel building. I recently completed construction-- and I probably made every possible mistake and then invented some new ones.
btw, I doubt that you are talking with an actual manufacturer. There are only two in the United States-- NCI is one of them. Lots of companies come up with "their" design and then have NCI or the other company fabricate their building. Just curious-- is the building supplier also willing to do building erection, or do you have to find someone else to do that?
   / Can you negotiate the cost of a building #3
Whatever is bought can usually be negotiated. The amount ($$), details (free shipping, extra parts, etc.) But with the tariffs about to kick in I'd recommend you do it quick.
   / Can you negotiate the cost of a building #4
   / Can you negotiate the cost of a building #5
Plowhog is correct. I was looking at steel buildings along with the polebarn people. Renegade steel is one of the few who buys their steel from a manufacture then makes some of their own parts. Same as pole barn builders. Morton who I elected to go with makes all their own parts. FBI buildings is also like Morton. I didn't negotiate much as Morton is pretty firm on its prices. But I was allowed to to pick and chose what materials and design I wanted with the budget i had. The steel building has more 'middle men' involved. Most steel builders don't erect, just supply the metal. So that makes you negotiating with the steel people as well as the erector. Morton is doing everything but the concrete...which I will do. Steel buildings when done correctly requires a engineered concrete design for the anchor pilings. Usually 3' diameter holes 4' deep at each post. Never hurts to negotiate for anything !!
   / Can you negotiate the cost of a building #6
Panic buying to avoid Tariffs?
Not a wise idea in my opinion!
   / Can you negotiate the cost of a building #7
Looked into this yrs ago.
Most of the steel building guys are just middleman,selling a building "kit" only. They offer no construction or the critical foundation design. They will deliver you the parts and be done.
OK. What I am looking at is a new process for steel buildings, called Cold Rolled steel. I was something an architect in LA recommended. It is lightweight steel framing, instead of heavy red. The reason I am looking at this system is that you can treat the concrete differently (Like a pole barn) which is significanlty less to install than a normal Monolith slab. They company claims to do the cold roll forming, I am looking for alternatives to do competitive bidding with but not having any luck.
And if you are still wondering on cold rolled, it is a system that is used in building storage units.
   / Can you negotiate the cost of a building #9
Good luck! They are probably back logged about 6 months at this point and have many more customers wanting on buildings.
Most contractors give a bid with the understanding that they give you their best price knowing you are getting other bids.
In general, we’ve found that the ones who are trying to haggle before the project even starts tend to be difficult. Often times not worth the effort- especially in this economy.
If they can be there quickly you probably don’t want them- again, especially in this economy.
And I am referring only to the materials. Not the labor. My neighbor erects steel buildings. He will handle that portion of the show.
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A55788)
2017 Freightliner...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
Toro Multi Pro 5800 Turf Sprayer Cart (A55787)
Toro Multi Pro...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
