air ride seat?
/ air ride seat? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I hope this topic isn't beaten to death already.
I'd like to look at adding an air ride seat to my Kubota F3990. Even in low speed, I get bounced around pretty bad that I end up with a sore neck / back after 3 - 4 hours of weekly mowing. I'm 33 years old and still get sore, if that gives any indication as to the condition of my yard and why I should probably just pave my back yard :laughing:
Knowing nothing about air ride seats, the sticker shock is pretty high. If I decide to pull the trigger, I guess I want to make sure I am buying the right brand and be done with it.
Are there any downsides to an air ride seat that I'm not aware of?
I believe I have enough width for the seat to fit...but this mower is like a billy goat and I want to make sure I will still feel comfortable when mowing slopes.
/ air ride seat? #2
I infrequently have dreams of an air ride seat. I'm sure if I researched long enough - there is a suitable model for my tractor. BUT - as you said - $$$$.
The one thing I wonder about but have never heard a negative comment about - rupture or puncture of the "air bag".
My "lawn" is really a big 'ol meadow thats been mowed for 36+ years now. Over the years its filled in and actually looks pretty good. BUT - talk about a rough ride when mowing. I've given up and simply go slower - saves the back, the neck, the kidneys, the bladder etc, etc.
BTW - I'm 76 and its been "paining" me for going on 36+ years. You are 33 - you should make your move now or , like me, look forward to at least 36 more years of pain.
/ air ride seat? #3
Cost is the biggest downside. We have several air ride equipped tractors and so far no issues. The oldest one is going on 12 years.
I have a newer Kubota zero turn that has a very good suspension seat and its pretty good but doesn’t compare to an air ride (which is on my short list).
/ air ride seat? #4
We have had to repair / replace a few of our air seats they are nice but expensive, the other option may be to slow down and go wider :cool2:
Down in second gear at 12 feet wide is fairly productive
/ air ride seat? #5
I believe Eric the Oracle did a thread on this.
/ air ride seat? #6
I've added spring seats to my skid steer and mower and I'm very happy with the results. Generally I pick the model that I want (don't forget to calculate for headroom!) and then start watching CL and eBay for it to come up for the right price.
/ air ride seat?
You hit the nail on the head. I want to either get one now or I'll just suffer through it. I really don't go 'that' fast, I keep it in low gear. Even with the 72" deck, it takes several hours.
How do air ride seats feel when leaning the tractor to the side? (i.e. going across a slope) As far as head room, should I expect a large increase in seat height? Being a shorter guy, I don't want to put extensions on my pedals :laughing:
/ air ride seat?
What brand seat have you had good luck with?
/ air ride seat? #9
Funny I beat around the bush on this for 2 years. Right Larry?! I finally ordered 1 yesterday. a Milsco V5400 for 559.95. Should have it in by Thursday.
/ air ride seat?
Care to share your reason for that seat? Maybe your thoughts on it after it's installed?
/ air ride seat? #11
You are gonna love t, worth every penny.
/ air ride seat? #13
I put the Milsco V-5400 on my SCAG Tigercat last year and my back thanks me every time I mow. It takes the HUH out of the bump. It was expensive, but so are doctors and chiropractors. If I had it to do over I might have even spent a couple of hundred more for a Grammer MSG 75 which has 3.1" of travel vs 2.3 on the Milsco. I saved the old seat, so if I get a new mower, I'll keep the air ride seat for the new mower.
/ air ride seat? #15
The air ride is just up and down there is a mechanism that keeps the seat stable. It's just the steel spring is replaced by an air spring.
As for the seat height you need to compare your existing seat and mounting to the new one in both the min and max height condition. For mine, the height didn't change much. When operating, you want the seat to be in the middle of the travel so that it goes up and down to react to the bumps.
/ air ride seat? #16
I bought a mechanical suspension seat for one of my rubber tracked machines and it was a huge improvement over the fixed seat. Cost $800 but was worth every penny. I only use this machine around ten days a month but those days I am in it 10-12 hours a day. I went from being beat up and sore to not minding the time in it. I looked at the air ride and the cost was comparable but it raised the seat too high for my application given the size of my cab. My only regret was not buying this seat sooner.
/ air ride seat? #17
I'm not familiar with air ride seats, in fact I've just had my first mechanical suspension seat with my new tractor and it's like 1000% better than my old one, that was a Kubota B7000.
Anyway, I was just brainstorming a bit and come up with an idea. What if we could add an airbag to a mechanical suspension seat and make it a low cost air ride seat?
I've just found these:
Sold by Revzilla for bikes
I shouldn't be too hard to add either 1 or 2 of these and make a good air ride seat. Or maybe someone knows a better source for airbags of this size.
/ air ride seat? #18
I think I remember seeing something like that in McMaster Carr.
/ air ride seat? #19
You are right. They have another types and bigger ones also. I would imagine this would need a shock absorber.
/ air ride seat? #20
All you have to do is put a soccer (or right sized ball) under the seat and air it accordantly...
It works pretty good too...
SR
UNUSED RAYTREE RMH680 HYD HAMMER (A62131)
UNUSED RAYTREE...
Bandit 2290 TK Track Chipper (A61166)
Bandit 2290 TK...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
1986 Ford LNT8000 Gravel Spreader Truck, VIN # 1FDYW80U5GVA28257 (A61165)
1986 Ford LNT8000...
2019 GENIE S-60XC' TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC'...
