Good morning!!!!
   / Good morning!!!! #77,281
That’s my concern also Randy. What model do you have?
I got a little ZD 20.
   / Good morning!!!! #77,283
High of 92 today wicked t storm came thru about 6:00 PM one half inch of rain in 30 minutes lots of close lightning that crackled as you saw it. Repeat for tomorrow but maybe more rain.
Randy prayers sent for Ellen’s mom and your grandson
Great sermon today in church about shame
   / Good morning!!!! #77,284
Our Toro Z Turn has lift like the one posted above and it is a 2005 model
   / Good morning!!!! #77,285
Good evening to everyone! Went up to a high of 92, slight breeze, but occasional gusts / dirt Devils kicking up mini dust storms. Same forecasted for the next 7 days....I am so over this drought!
Son and DIL are still evacuated, they have evacuated another 1000 homes today. Wind, extremely low humidity, and an abundance of dry fuels.....not a good combo- fire has tripled in size the last few days. It is amazing they have not lost one structure. Only 10% contained.
Well, I survived my first week back on light duty. It was really iffy the first couple of days, but knee has really been improving. A few instances of pain, and can tell it "gets tired", then just a little swelling. Maybe I'm over the hump...
Yesterday and today were the first time in 3 1/2 months that I was truly able to be productive on the homestead.
1) All that mulch that I picked up a couple weeks ago was finally spread. I'm one load short. Going to get it tomorrow. Then finish up.
2) The "cutting of the 1/2 fence" project is complete (neighbors keep coming by and complementing the property, saying "never knew it was that pretty behind the fence").
3) Got the misaligned (infringing 3' onto our property) neighbor's fencing, posts, and H posts all taken down, 350' worth. Actually 700' worth. I attached a second layer of 2x4" welded wire fencing onto his field fence, it had to come off first. I will never, ever, attach a fence that secure again in my life! I have numerous blisters from cutting the bailing wire twists--4 rows, every 16", for 350'. Then graded / prepped the line to install a new fence where it should be. Going to tackle that project next weekend.
Now if I can do a rain dance that would work, I'd be a happy camper......
Prayers out to those needing... Have a great start to the week!
   / Good morning!!!! #77,286
I think, when I take blades off for sharpening, I’ll use the onboard maintenance lift first, if that isn’t high enough I’ll use one of our FEL’s as well. I like to do all work without really getting underneath the deck. With a 72” deck, opposed to prior 60” deck, the middle blade will be the biggest challenge. I’ll probably put my farm jack under middle of deck, for safety, for that one. I trust farm jacks less than anything I have.
FWIW, I trust my FEL’s over the Kubota lift system, that I’ve yet to try.
   / Good morning!!!! #77,287
I suspect theyæ±*e CFL bulbs Don?
Yes they say Fluorescent on the bulb and it also says not to use on dimmer switch. They are at places that are usually not dimmed anyway - kitchen, bathroom.
Rick as Roy said, Mikim died while using the FEL and a chain, I think the chain slipped. You may not be under it but I bet you are a candidate for a severely broken arm. I can just hear Mike's last words "That thing ain't going nowhere."
Kyle, I was thinking the same thing that the hot tub would be un-refreshing. I forgot my hat and sunglasses working out so I'll hit the pool tomorrow. Whipper made it a block on the leash till she saw some kids playing in a yard and would not go past them. They won't be there long just visiting grandma.
   / Good morning!!!! #77,288
Z Turn is 60 in deck with mulching deck and striping kit. We have two sets of blades that we swap out once a month. Have found this works well for us. Due to our uneven terrain the 60 in deck works best for our application with less scalping and better overall cut. Use a thunder gun air wrench to change them and keep myself clear should something happen
   / Good morning!!!! #77,289
Don, I lift the ZT with certified 10K lift slings, so no slip. I like living so, I’m overly cautious. Guess that’s my engineering education.
But, thanks for caring!
Glad to hear you’re getting settled in my friend.
   / Good morning!!!! #77,290
2018-06-11, 0313
41 right now...high in the mid-70's.
Didn't get to assembling the Mojack yesterday, but I did finally mow the field. The grasses were 2-4 feet tall and I went pretty slow (so any small critters have time to get out of the way). Next mowing will be in a higher gear.
Wife and stepdaughter are flying to visit another stepdaughter tomorrow, so I'll be babysitting the dog
Back to the grind today...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A57453)
2004 Ford F-350...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
206320 (A57192)
206320 (A57192)
