Bigfoot62
- Joined
- Aug 5, 2008
- Messages
- 2,478
- Location
- W. Central Louisiana
- Tractor
- JD 5090M; JD 5085M; JD 5083E; NH TN70A; Ford 2600
I need to know if you have had (are having) issues with the EPA mandated garbage that JD has to put on these tractors now. I'm thinking about picking up another used 5M, and I need to know if emissions trouble is a real issue or not.
As you can see in my signature, I already have two 5-series tractors, one M and one E. Both of them, and both of my blue tractors, are all pre-emission. I'm looking at purchasing another cab tractor, probably a 5M, likely a 5100M. In any case, I don't want anything lower HP than what I already have, and would like a little more. I have about 110 acres of land, with about half of that in hay production. I average about 500 tractor hours per year combined. (approx. 200 hrs each on the cab tractors, and another 100 on the open stations)
Most of what I'm seeing on the used market is more newer than older. A lot of 2014-2016 models. So, Tier III, Interim Tier IV, and Tier IV. I'd love to hear your real-world stories about the pros and cons of the newer set-ups.
So, PLEASE, if you have a 5-series (or 6-series with the same 4.5L motor) that has a EGR, DPF, Regen, DEF, or Catalyst, Respond to my "poll" and tell me your experience: good or bad.
Please state the model number, year, hours, and emissions Tier. Thanks
