LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 11,198
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
That's right; it never had one and you'll never need one. Cut it off, grind the edges smooth and call it good.
A hammerstrap is used mostly on tillage tools that pulse to and fro (hunt) and pound the cr@p out of a drawbar by elongating the hole. A hammertrap slows this action way down. Save it, just in case.
When you bolt the drawbar bracket back on, I would use grade 8 bolts and lock washers with a drop of blue locktite. Sometimes brackets loosen up and you don't want a casting break.
We very seldom have need for the hammer strap, it adds shear points to the draw pins doubling up the pulling capacity. However we have never used one even with Chisel plows that can and have spun out the 4wd IH Magnums, pulling forage choppers with an attached forage wagon with tandem rear axles anchored to the tractor with a single 1 inch or 1 1/8 inch draw pin.
Also even though that is called a swinging drawbar we have never used ours with out having it pined in position, it should be called an adjustable draw bar.
