California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,641
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Listen to sixdogs (previous post). He's talking quality work, as good as any body shop.
One comment - Note the guns described there want more than 10 cfm of air.
If you only have a smaller compressor rated around 5 cfm @ 90 psi - then the HF gun shown at $15.99, often sold at $9.99 and occasionally $8.99 does excellent work. #47016 etc. It is rated 'average air consumption 6 cfm @ 40 psi'. I see that one has 652 comments in HF's description, nearly all favorable. Some posters here have said the quality of finish it will lay down is plenty sufficient for farm implements. That was my experience on a project applying Rustoleum primer then Rustoleum low-sheen white on cast iron lawn furniture, I couldn't have asked for anything better.
I had a HF $40 pressure regulator / water separator (a model no longer sold) halfway to the gun, and set it to show 40 psi on a gauge at the gun while spraying.
Also, I used HF's paper cone filters after stirring in solvent, and again at filling each cup, because I began the job with years-old leftover materials. With the old paint thoroughly stirred and filtered it went on same as the new materials purchased to complete the job.
