culvert question
/ culvert question #11
I'm not there so I can't say for sure. I don't know how well the material is distributed around the culvert. Even distribution is the only thing that gives it crush strength. Loose rock tries to move out of the way. So is the culvert in a narrow deep trench so the sidewall material is compressed against a solid bank? Or was the dugout a wide area that's been filled with several inches or feet of loose sidewall material? So not the top of your fill is below road level and you are just trying to fill the hole??
If you are using 3/4" gravel and you only have 1/2" of material over the culvert then it's inevitable that you can see the top of the culvert. I dunno. Proceed at your own risk I guess.
/ culvert question
It has been dug ou a few inches wider than the culvert. I'll be driving my RAM and a dump trailer with about 2 yds of gravel. I won't be doing this for at least a month or more until it dries out around here. I guess I'll bring in some gravel with the loader for the first round and then drive over it and hope for the best.
/ culvert question #13
Yup!
That is the right idea.
You are working in recently frozen ground that now has lots of voids around the pipe.
Put 4+ inches more cover over the pipe.
Some old plywood to drive over would help too.
/ culvert question #14
Are you sure you have to shovel it into the bucket. If you have a 5' bucket you can do this.
gg
/ culvert question
I can't put wood down since I will be spreading the gravel as I go over the culvert.
I can get one or two bucket loads with the loader but after that I have to shovel. The trailer bed is 12 feet long.
I thought about closing the gate and dumping the load to the rear a bit but I'd have a mess when I open the gate. I think it would be hard to control since when it goes, it goes.
/ culvert question #16
You didn't say how long it's been there???
If it's a fresh install, I'd probably try to get more cover before crossing with a heavy load.
If it's been in the ground thru a couple weather seasons I wouldn't worry about it at all. I've got some on public roads that have eroded with no more than a couple inches of cover. They get crossed by 80K lb semis full of grain.
If you can compact the sides some more that will be more beneficial than additional cover.
/ culvert question #17
I'm looking at putting in about 60 feet of 24 inch pipe but it will be covered with possibly 8 feet of dirt and material to build up a low spot. what would the TBN pros think, will it hold that much weight?
/ culvert question #18
I have a 15" with 2" over it and it accepts anything I run over it with. What really maters is that you pack it well on the sides before putting a top layer on.
IMO that is the key.
/ culvert question #19
I just installed it today. There is still a bit of frost in the ground too. I put the gravel I dug out around it. I'm going to pack it down best I can.
It looks good to go - adding some more gravel to take out the dips from settling is a good idea, but it looks solid. 12" is a rugged size.
If it was me, I wouldn't hesitate to drive your pickup and gravel trailer over it.
I've watched 11 yard dump trucks drive over my 16" corrugated plastic culvert without problems - 6"-7" of gravel. Culverts are designed tough!
/ culvert question #20
Not sure I understand the question??
Adding depth of fill won't compromise the pipe at all. I've buried some 30ft deep. More isn't a problem. Less is a problem. :)
207269 (A52708)
207269 (A52708)
SY225C SY225C9C5KL EXCAVATOR (A59823)
SY225C SY225C9C5KL...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
John Deere 270A (A60462)
John Deere 270A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
