   / Harbor Freight Tools that don't suck #8,601
Come to think of it I've seen a lot of smoke from my HF compressor when it couldn't keep up with a HF die grinder claimed to use less air than the compressor spec. I've only had to replace the pressure switch in some 10 years occasional use. That smoke didn't seem to hurt it.
I don't recall smoke from anything else. But the $9.95 angle grinder got even noisier than usual, then eerily quiet. Turns out its internal fan disintegrated. I cleaned out the debris and it continues to run fine - but I don't use it for more than moments now. That probably was a parts failure due to heat.
   / Harbor Freight Tools that don't suck #8,602
Does anyone have the plastic storage bins? What is the plastic like? Does it seam like it would break easily if it was dropped or over loaded? I have too many nuts, bolts, and other assorted small items and for several years I have added them to my Christmas list with no luck. I'm at the point now where I'm just ready to buy a couple. I didn't want to buy one on-line (unless it was a name brand $$$) without seeing it or at least hearing what others, not the reviews on HF, have to say. Today's plans have changed and I could be going sort of close to a store this afternoon so I was thinking of making a detour but was hoping to hear from what people have to say.
   / Harbor Freight Tools that don't suck #8,604
I either bought, or compared several of the bins from HF to other places. The trays and the boxed drawer varieties are all on the low end of the equality scale compared to others. I ended up buying most of mine from Menards. The HF plastic is thinner, distorts, and cracks easier if fill with heavy hardware. For lighter use or a few screws/bolts, they work fine.
   / Harbor Freight Tools that don't suck #8,605
   / Harbor Freight Tools that don't suck #8,607
   / Harbor Freight Tools that don't suck #8,608
I ended up getting the 74 bin floor stand model. I figure I can assemble it without the feet and screw it to the wall. With a 20% off coupon it was only $60. They didn't have it out on display so I couldn't see it so hopefully the plastic isn't too bad.
While there I picked up some more 4 1/2" cut off discs. I also picked up a couple of these to try out since they were cheap. You can never have too many bar clamps. I'm curious how the aluminum will worked compared to the steel version.
   / Harbor Freight Tools that don't suck #8,609
I have several of the Clamp/Spreaders in various sizes. Used a couple of the to hold a glued in wall panel in place while glue and caulk dried. They work good for light to medium projects. Easy to convert from clamp to spreader.
HF was giving these away as freebies a while ago and I can't say as I had much luck with them. Even used gently they seemed to crack and die. I guess they were worth what I paid. :D
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2012 CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
2012 CATERPILLAR...
