SubSubsistanceFarm
Alrighty, Here it goes.
I would love to dig post holes with my kubota L4310. Currently i do them with a linemans digger and bars, this works in our soil, but obviously it takes a lot of time and effort, two things that are a stretched thin around here.
I would bet that i have at least 500 holes i want done eventually, not counting replacements.
I am in the hills in west central New Hampshire, we have some loamy sand, gavel, lots of rocks usually potato sized loose packed, but some get basketball sized and bigger. If i am digging a tree hole 3 feet wide and 4 feet down what comes out is half sand/soil, and half gravel rocks. Of that gravel and rock it is usually half in volume in gravel, and the other half rock, mostly potato sized with the odd large one. That is the usual, some spots are a no go, and some spots are nice and easy. I would say 20 percent of the time i am going to get this thing hung up into some football-basketball sized rocks, however this is not heavily compacted soil, it is fairly loose, stuff moves when pried. I feel an auger properly driven will be effective, it just is going to hit rocks.
I have no experience with post hole diggers, however from research i would guess the following.
A 3 point auger is going to be a waste of time and money.
A 3 point auger with down pressure is still going to be a waste of time and money.
A cheap auger bit is just going to get destroyed
A quality "soil" auger may last me some time maybe, but i would be better off with a carbide tipped "rock" auger.
Hydraulic drive on my FEL is the way to go.
Hydraulic drive on my FEL, from a larger pump off my PTO is probably the way to go.
I have a quick connect bucket, i could get a blank quick connect frame to weld a mount for the drive on.
From here i am wondering how far i should go with this.
My tractors hydro pump is rated at 7.8 GPM ( unfortunately i have not been able to figure out what RPM that is at) and i already have remotes up at the bucket. Would something like land prides HD25 which is rated for 5-12 GPM be enough? and i get a better auger, or a rock auger? would that even be enough to run a rock auger? I am talking 9 inch diameter. I am guessing this probably wont be enough, anybody with personal experience with a similar setup?
If that is not enough, it is going to get much more expensive. I'll need to run a higher (i would match it for the drive) GPM pump off my PTO, I'll need lines and connectors for there, a hydraulic valve to be able to reverse direction, and then the drive and auger.
At this point could a get away with the LP35, it is comparably cheap to others? then there is the SA20, seems i am going to be in the 3k ballpark at that point. renting a skid with a hydro post hole digger for a week is going to be over 2k. landpride seems to be economical compared to McMillen and BellTech.
Being able to run this in frozen ground would be lovely too.
Does anybody have experience running a hydro post hole digger with an FEL, with a PTO driven pump?
anybody have experience running that on a tractor of my size?
specs for my tractor are here. TractorData.com Kubota L431 tractor information
Thanks!
Thanks!
