?? About octane for mowers and chain saw
   / ?? About octane for mowers and chain saw #51
And to that I say, I remember lawnmowers, riding tractors, cars, etc... being left with fuel in them for long periods of time back in the 60s and 70s, well before ethanol, having their carbs gummed up from what old timers said "the fuel went bad". Take care of your equipment, follow the manufacturers instructions, use the fuel they recommend, etc...
Pretty much every chainsaw manufacturer tells you to drain the tank if you're not going to use it for a while.
The correct way to store chain saws: Instruction | STIHL | STIHL
Checklist: Storing your chainsaw correctly | STIHL Blog
Chain Saw Maintenance & Storage – Monkeysee Videos
(although this factory rep Echo guy is pouring gas indoors, yeesh!)
Let's face it. No one wants to do what's proper because its an inconvenience.
"No one wants to do what is proper because its an inconvenience"
You done hit the nail on the head there !!!!
At the end of EACH season,... I would only need to drain & dispose of:
10 gals. from my Ford 3400.
7 gals. from my 8N
6 gals. from my JD riding mower
3 gals. from my old Sears rider
2-1/2 gals. from my Toro mower
1-1/2 gals. from my Troy Bilt
6 gals. from generator #1
4 gals. from gen #2
4 gals. from gen #3
1-1/2 pts. from my brush cutter
1-1/2 pts. from my weed wacker
1 qt. from my chain saw
1 gal. of home brew pre-mix
2 gals. from my pressure washer
10 gals. from my 2 cycle outboard tanks
Yup!
I am 77 years old.....and you may feel free to consider me.....lazy!
   / ?? About octane for mowers and chain saw #52
7 gals. from my 8N
4 gals. from gen #2
4 gals. from gen #3
Yup!
Don't forget that your efforts are nearly a waste of time. After that trouble you've still got old fuel in the lines and carburetor. Buying ethanol free gas and pouring it in and forgetting about it is so much easier.
   / ?? About octane for mowers and chain saw #53
   / ?? About octane for mowers and chain saw #54
Haffners oil in Hudson NH has 110 octane racing fuel for 9.20 a gal at the pump.
   / ?? About octane for mowers and chain saw #55
Buying automotive ethanol free fuel is certainly a better idea, and I would prefer to do it.
FINDING automotive ethanol free fuel, at a distance that makes any sense, is the issue for me.
Perhaps you misunderstood. I do NOT intend to "waste" any time dealing with ethanol fuel issues. It just ain't gonna happen!
I have no reasonable access to ethanol free automotive fuel. I am UNWILLING to drain/run dry, ethanol fuel from all the engines I have listed.
Instead, I will continue to buy and use, 100LL, as it is the ONLY reasonable/locally available non ethanol option for me.
   / ?? About octane for mowers and chain saw #56
Using gasoline with alcohol in it is not a problem as long as it does not sit for more than a month. If any of my equipment is going to be stored for any length of time I drain the gas or make sure it has 0% alcohol in it. I ruined a chainsaw because of that.
I also fill my gas cans with the highest octane anything calls for. In my case that is 89 so everything burns that with no problem.
Using anything higher is just wasting money.
RSKY
   / ?? About octane for mowers and chain saw #58
7 gals. from my 8N
4 gals. from gen #2
4 gals. from gen #3
Yup!
Will do.
   / ?? About octane for mowers and chain saw #59
Could be, but Hudson, NH is well over 100 miles from me in SE, Ma.
100LL is usually priced at around $6.50/gal.
   / ?? About octane for mowers and chain saw #60
Could be, but NH is not near SE, Ma.
100LL is usually around $6.50/gal.
I know not close but, I called the station before I posted it the girl said 9.20 a gal never bought gas at a airport seems like security would be a hassle:)
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
Husqvarna 42in Riding Mower (A56859)
Husqvarna 42in...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
