Cab Electronics ie Tablet, GPS, Camera
/ Cab Electronics ie Tablet, GPS, Camera #1
BossTractor
Parkland County, Alberta
2016 John Deere 3032E
What kind of electronic devices have to added to the cab of your tractor?
Anyone running a tablet to keep track of snow removal client lists etc?
GPS guidance systems?
Android radios with apps?
LCD screens for back up camera, loader camera?
Outside air temp and compass?
Let's see those high tech cockpits
/ Cab Electronics ie Tablet, GPS, Camera #2
I added a back up camera simply to save my neck while snow blowing.
Works nicely. (even to -30 deg)
Most will accept 2 cameras so one could be dedicated to the FEL while the main one monitors your backing up operations all while saving your neck.
For entertainment I have a scrap yard recycle radio ($20.00) that works just fine for me.
Gives me AM or FM and all the news etc that I wish.
Compas? who needs that? Just follow your tracts to go back. LOL.
OK OAT maybe to know if you need to salt or sand.
/ Cab Electronics ie Tablet, GPS, Camera #4
Front loader cam, rear cam, and DVD player.
/ Cab Electronics ie Tablet, GPS, Camera #6
I use a tablet (or iPhone) to display previously taken photos of driveways for plowing. After a blizzard here several years ago I checked google street view when plowing drives I had never seen before. Works great.
Not permanently mounted, but I did add a usb charge outlet.
/ Cab Electronics ie Tablet, GPS, Camera #7
Well, I've got a $3 stick-on thermometer on my right mirror, a $5 stick on clock on the dash and a $10 cell phone holder on the right cab door handle.
Hi tech-ish, but definitely low dollar!:thumbsup:
/ Cab Electronics ie Tablet, GPS, Camera #8
I have a raven cr7 gps I move between my kubota utv we use for spraying and the tractor. It helps reduce overlap with the batwing. Any little bit helps to speed things up
Brett
/ Cab Electronics ie Tablet, GPS, Camera #9
I have a Rearview Systems 7" monitor and two cameras:
Rear 130 degree wide view camera is mounted in the tail light bracket:
I can see the coupler and back the ball under it:
Front 50 degree narrow view camera is mounted over the right front wheel:
Looking from the seat with a 5x6 round bale on the bale spear:
The monitor shows what I can't see out the windshield:
The field of view graphic:
/ Cab Electronics ie Tablet, GPS, Camera #10
Are these the RVS heated cams?
/ Cab Electronics ie Tablet, GPS, Camera #12
NOPE, my $50. ish system is not heated and works down to -30deg.
To note however I use a remote toggle switch to power it as I did not trust the flimsy built in device.
AS to camera location I mounted it up high under my rear roof overhang (a mere 3") so snow never gets to it.
I'd suggest that a tiny 'hat' or shaped 'roof' would keep the camera clear.*
This highish location looks down somewhat but has proven not to be a problem.
In fact low would see shadows while high sees beyond.
The only weird effects is when I am blowing snow and have my yellow beacon on I constantly have intermittent blasts of yellow snow. LOL.
*unlike a car whereby snow is sucked up due to speed tractors while working rarely travel at a speed that would suck up snow.
Also note that I only use my camera to blow snow, and that in all kinds of windy conditions and never had a snowed over camera.
My display is mounted front center just above my steering wheel and low enough that it does not hinder forward visibility at all.
Actually with the windshield close I just clear with gloved hands while steering.
(when or if I need gloves, as my cab is heated)
/ Cab Electronics ie Tablet, GPS, Camera #13
Considering a camera system for the back of snowcat, interested in a heated one if it would melt off snow at reasonable rate.
/ Cab Electronics ie Tablet, GPS, Camera #14
I have a Galaxy Tab-E mounted over the dash I was planning on using to help cut/plow straight lines. :ashamed: I can't find any good free or simple apps to do it though. I carry my Galaxy S8+ phone in my pocket to act as a Wi-Fi hot spot for the tablet. I guess I could just use the phone mounted on a holder for headings but there's no way to "buffer the bumps". And the compass doesn't like being held vertical.
/ Cab Electronics ie Tablet, GPS, Camera #15
Have a sprayer control and a GPS in my cab. Don't necessarily like the way I mounter the sprayer control, nor the style the controller is, but I got it for free so I didn't complain. . Eventually want to get a round baler and mount a camera on the baler as well as moisture monitor in cab. Probably will make a console like Bagwell Farms did to mount them, (Link Below). My GPS I built a stand for that works pretty good.
Feeding cows finished console - YouTube
/ Cab Electronics ie Tablet, GPS, Camera #16
Good post. Thanks for sharing that.
I don't have a cab but really would like to have two cameras. I use my forks a lot but can't see the tips when they are level with the ground I would be nice to mount a camera on the front of my FOPS canopy that would look forward and down at the path of the blade/forks and one on the rear so I could more easily back my snow blower ups and also check for short people/things in my way when backing. Because everything I have is pretty much "in the weather" I would probably have to remove my monitor or make a cover for it. Suggestions?
/ Cab Electronics ie Tablet, GPS, Camera #17
I went with Rearview Systems because it is made for commercial heavy duty use and the 5 year warranty.
Installed it 9/2/2012, no problems. Use it every time I drive the V417.
It is waterproof, IP65k rated:
Rearview Commercial Duty 7" Backup Monitor
/ Cab Electronics ie Tablet, GPS, Camera #18
Thanks, very nice unit but a bit out of my willingly-paid price range. I think I'll try building a box for a 7" designed for inside the car. Maybe something like this for $80 delivered? Anybody built a weather proof case for a monitor?
/ Cab Electronics ie Tablet, GPS, Camera #19
I installed a Ag camera with monitor in the 8560 for front fork positioning under pallets. The system accepts up to 4 cameras, I added 2 more so far. 1 for a rear view and a wire to connect a 30 or 60 foot cable for planter, corn sheller, gravity wagon or any other application.
Used Video by Jim out of Texas, does a lot of custom setups for Ag applications and stands behind his products.
I also use a I-Pad for spraying and planting using a external GPS Antennae Bluetooth to the Ipad with Field Navigator or Farm Tracks apps for guidance lines. Not good enough for precision planting but good enough for Spraying and Fertilizer.
/ Cab Electronics ie Tablet, GPS, Camera #20
What antenna are you using? Is it a direct plug and play type system? I've been looking for something for spraying/mowing to decrease my inevitable overlap and save a few rounds.
I've been looking at getting a Raven CR7, but the system is expensive for my needs... although having future option for autosteer seems nice... I don't think it would ever realistically be worthwhile for me, unless I had a big $$$ change. But I would like to get a spray accuracy level, GPS if possible.
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2020 INTERNATIONAL...
2022 John Deere 5055E (A62177)
2022 John Deere...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2012 International 4300 Reefer Truck (A63118)
2012 International...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2009 Chevrolet 1500 Savana Van (A63116)
2009 Chevrolet...
