Rotary Cutter Brush Hog Question..?
/ Brush Hog Question..? #1
Buckchaser
Member
Bradford PA
Massey F 1734
I'm looking for a good used brush hog ( vs. new ) Does anyone have any thoughts on the best brands out there from your experience ?? I'm going to look at a used Woods ( Dixie Cutter ) next week..Don't know anything about this model but I've heard Woods makes pretty good equip. I used to own a 6 ' Bush Hog several years ago, but had to give it up..It went through a lot of hard use and still held up well.. I'd rather try to find a good used one vs. new. Any advice from you guys would be helpful.
/ Brush Hog Question..? #2
First, you'll have to decide if Ford or Chevy is better. :stirthepot:
In my experience, there are almost NO decent used cutters in the market. Everything I found was rusted or beat all to ****. With a shot (or questionable) lower gearbox seal.
So my :2cents: if you can find any, is just to stick with a long-term manufacturer with a good reputation for customer service so that you have some chance of finding parts. And accept that you will likely have to invest some labor in reconditioning.
/ Brush Hog Question..? #3
I agree concerning parts availability. Check your local area for new cutters and remember what brand they sell. Try to find one of those.
I can't think of any situation where I'd buy a new brush cutter. Used cutters in excellent condition can be found for 70% of new price and down. Very nice cutters can be found for 50% of new price. If you are mechanically inclined and patient you'll find a very good used cutter for 25% of new price.
I've got a JDM1008 10ft 3pt mounted cutter that I've got $2300 in. Very dependable tool that will outlast me.
I've got a Rhino 6ft mounted that I've got $650 in. Very dependable tool that will outlast me.
/ Brush Hog Question..? #4
I'd go with Bush Hog or Woods. The Dixie Cutters seem to be on the far lighter end of the Woods line. I have not had good luck with Howse cutters - the hitch is weak and prone to warp / bend. If your used cutter has a leaking gearbox, double aught (00) grease works well. 800 bucks will buy an excellent used 5' cutter around here. 1000 to 1200 will buy a really great 6-footer. Good luck.
/ Brush Hog Question..? #5
Yep, your prices are very comparable to ours at a dealer. Knock off 20% if buying from an individual.
/ Brush Hog Question..? #6
That is spot on the market around here also. I had to drive 160 miles one way to get a lightly used Brown 472. At $1150 I was a happy camper.
/ Brush Hog Question..? #7
How big are you looking?
How much tractor do you have?(your profile says none)
And what do you want to cut? Pastures 3-4 times a year is a whole lot different than than virgin crp ground that hasn't. Been Touched in 8 years
I should have said what I would be using the brush hog for.. I have about 15 - 20 acres of field . It was mowed last year and has no brush.. Just rough hay and weeds and mostly flat with no hidden stumps or rocks. I'll probably be mowing a couple times a year with a 34 horse Massey F. I'm looking at getting a 5' brush hog.. /wasn't sure if a 6' brush hog would perform as well with 27 PTO HP.
/ Brush Hog Question..? #9
Will a 5 ft cover your tire tracks? If not I recommend going with a unit that is at least as wide as your tractor.
/ Brush Hog Question..? #10
Yep, definitely cover your tracks.
I think your tractor would power a 6ft in the conditions you described. If you get behind, just go slower.
/ Brush Hog Question..? #11
Anybody know a good starting torque for the clutch on bush hog? Im thinking start around 15-20ft lb and tighten 1lb until non slip?
Thanks/Robert
/ Brush Hog Question..? #12
Usually not a torque setting
Rather a measurement of the amount of spring compression if it has coil springs.
And a gap setting if it has a big belleville washer/spring
/ Brush Hog Question..? #15
Yes Sir, That is good reading, I think I can go from there. Thanks/Robert
You are welcome. I didn't want to offer specific numbers because of variations. Hoping you can find your model amongst all that info. Ain't Google great!!!! :D
/ Brush Hog Question..? #16
Again - you guys are so fortunate. I've searched every internet sales site for ANY used ag equipment - zero, zilch - natta. Ea WA and surrounding environs are a true wasteland for any such equipment. I've simply resigned myself to new purchases.
/ Brush Hog Question..? #17
I've heard others say that too. I've never looked for a used piece of equipment that I couldn't find in 60 days, condition and price matching my criteria. Sometimes they can be found in a couple days. Totally depends on what the item is and how picky I am. :)
/ Brush Hog Question..? #18
Ah - I'll have to retract my previous statement - a bit. About 8 to 10 years ago there was an ad in the local newspaper for a tractor and attached sickle mower. Went and saw it because it WAS in this area. Couldn't even begin to match the selling price. Reason - the combined tractor/mower was so DAM old that it was purchased by some museum as a true antique.
The sickle mower was driven by a gear arrangement off the inboard cogged wheel - no PTO on this system.
And that is the total extent of what I've found to be available in this area for the last 8 to 10 years - period.
/ Brush Hog Question..? #19
I don't know about anybody else but IMO your gambling when you buy a used bush hog . I realize money comes hard I can promise you that..... but if I'm going to buy a bush hog 2 things are on my list 1st buy a good unit with good part supply if needed 2nd It will be new for warranty..... I will be the 1 to tare it up or try too. Every used unit Ive ever looked at was a complete gamble..... from gear box to the deck to the drive line and lastly the 3pth..... Liquid over haul (paint) covers a lot and people will say and do anything to sell it. I say the **** with that I will buy new that way I know what I have! Its your $$$$$ You get what you pay for...... but also if you buy new you have something for your hard earned $$$$$ not a lot of headaches and no production. Have a good 1
/ Brush Hog Question..? #20
Besides that we basically don't have any used ag equipment in this area - in the 100 hp and under range. I feel EXACTLY as jdtractor does. If I'm going to spend my $$$ - I don't want to be buying somebody else's problems. Problems can come soon enough with brand new equipment.
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
