Backhoe L39 Backhoe Install
   / L39 Backhoe Install #11
Just an update on this post. I have an L39 with the BT1000 backhoe and the instructions are in front of your feet on the backhoe controls. It also makes it easier to install and uninstall the pins by using a dremel/air tool with either the round sanding fins or the wire brush attachment to clean out the holes where the pins are inserted. Then I put a little antisieze on the pin. The first couple times I removed the backhoe I had to use a pry bar and hammer to get the pins out. After dremeling the holes where the pins go it made it much easier. Some of the paint and rust makes little high spots that don't allow the pins to release. The other thing to do if the pins won't release is gently raise and lower the back of the tractor off the ground with the backhoe and watch the pins. You will see them slightly move when the pressure is released. My left pin comes right out when I lift the tractor off the ground, but the right pin needs the tractor just touching the ground for it to release easily.
   / L39 Backhoe Install #12
Sorry that I am late to the party, but attached are the Kubota instructions.
I have found that it is easier to reattach the hoe if it is parked on a block (I use a section of railroad tie) rather that lowering it all the way to the ground. Doing this will give you a little more maneuvering room to jockey the tractor when you are reattaching.
Smooth_Pilot,
I just recently purchased an L39. Do you know where to find a digital copy of the service or owners manual?
Thanks for the help
   / L39 Backhoe Install #13
2005 L39, Never had the hoe off. I couldn't imaging what it would be like without the 1,800 Lbs BH Counter weight. It would probably be like a normal tractor except the loader would try to kill you.
Nice to have other tractors available.
   / L39 Backhoe Install #14
There are several videos on youtube, showing how it's done, in case the written word doesn't make sense, watch the video. It still takes me 10 minutes, but I have only removed my hoe once. it really is a 2 minute job.
MrC.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
LOT: Kimball Midwest 4-Drawer Hardware Cabinet w/Contents & Stand (A59076)
LOT: Kimball...
30ft Highway Trailer Co. Lowboy (A56435)
30ft Highway...
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
