Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,281
Adding another pic, bigger size.
   / Tractors and wood! Show your pics #5,282
I am planning on buying either the More Power Puller or the Tom Hoffmann U-Rig Kit from Treestuff.com
Website Here
Leaning toward the kit. Since I own a small tractor, might as well use it, instead of pulling by hand.
   / Tractors and wood! Show your pics #5,283
Is there any way to prevent the stickers from leaving darkened streaks across the boards?
Yes, use DRY stickers of the same species you are stickering...
They must be DRY though...
SR
   / Tractors and wood! Show your pics #5,286
I've had that situation before. Misjudged the upper weight of a tree, and on the side of a hill, so it fell into the tree next to it, instead of away from it. Then cut it again and it jumped off the stump and sat in the dirt. Here's how I got it out. Not recommending you do it, but its what I did....
I made another notch on the side opposite of the tree its leaning against. Then did the back-cut on the side by the tree its leaning against. That made the leaner collapse towards the tree its leaning against. It jumped down into the dirt again, but the butt end was now a couple feet closer to the base of the tree its leaning against. Had to repeat that process 2-3 times before the leaner finally fell away from the tree it was leaning against.
But each situation is different.
Good luck and watch out for falling branches if you are working under that thing. Wear a hard hat.
   / Tractors and wood! Show your pics #5,287
Do you think the caveat limits your liability?
   / Tractors and wood! Show your pics #5,288
Mossroad, I've done what you did several times with a lot smaller trees. This is a big oak, and I'm scared! :roadblock:
   / Tractors and wood! Show your pics #5,289
I don't think your 1715 is going to do anything with it. If I were you I would tie it to the other tree and then cut a lot of limbs off of it. This will make it a lot lighter, less likely to catch on other trees, and also much more predictable on where it goes and what happens. After you do this you will be much better with Moss's recommendation.
   / Tractors and wood! Show your pics #5,290
I’ve pulled the base out from under a bigger oak than that but I had a 12000 pound CTL to pull with. There’s no harm in trying because it’s the safest way IMO but it’s probably not going to work.
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
BUYERS PREMIUM & PAYMENT TERMS (A51222)
BUYERS PREMIUM &...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Landoll (A50657)
Landoll (A50657)
Wilrich Field Cultivator (A50515)
Wilrich Field...
