s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,607
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
First off, to the OP, look in the user manual for your front loader, and you'll see a lift curve that shows lift capacity versus height. You will see that there is not a "single" lift rating and that your loader can lift quite a bit more down low.
Note that the "paper" spec for a loader rating is always given at maximum height. Last time this topic came up, a newbie was comparing a Kubota loader to a Mahindra, and on paper the Mahindra lifted more. However, the Kubota loader lifted higher by 12" or so. If you looked at the rating of the Kubota loader at the lower height of the Mahindra, it was the same.
So, again, look at the lift curve for your loader in the owner's manual. And then when comparing to other tractors and loaders, compare at equal heights to make it apples to apples.
BTW, this doesn't just apply across brands. I remember seeing a spec where a B Kubota could marginally out-lift an L Kubota "on paper", but then you realize the L loader tops out about 10-12" higher than the B loader, and it all makes sense. Compare them at the same height and the L can lift substantially more.
It's all about apples to apples.
