Frozen DEF
/ Frozen DEF #1
3930dave
Super Star Member
Canada
Ford 3930
I'm scratching my head over this one....
Heard a few guys talking about late model pickups here with frozen DEF tanks, and no Fault Codes.
I know of vehicles (Cruze for example, also some TDi's.....) that have had the DEF tank heaters fail, but usually throw codes when that happens.
So assuming these pickups had working DEF heaters, then what are you supposed to do when the temperature starts heading to -40 ?
Other than leaving the truck running all night, or parking in heated garage, what other options are there ?
Rgds, D.
/ Frozen DEF #2
Rgds, D.
I have thought about that myself, and sure don't have any answers. The whole DEF thing looks like trouble waiting to happen. Especially in cold climates.
/ Frozen DEF #3
It freezes at 12 degrees Fahrenheit according to google. That sounds like a terribly thought out plan. I guess if parking inside isn’t an option you’d have no choice except to add a heater. It’s a good thing my 1992 Chevy doesn’t have any DEF to freeze.
/ Frozen DEF
AFAIK, anything sold here will have heaters built into the DEF tank. Youtube has examples of people replacing them on Cruze's - PITA to deal with, but at least certain of those years don't require dropping the tank. Some thought went into servicing a "Replace within ...... miles, or total shutdown will happen" item.
All that ^ aside, I've always wondered - What happens when the vehicle sits through an extended (Canadian) cold snap ? If the DEF tank heaters are any kind of wattage at all, they'll flatten the battery quickly.
Battery charger + re-programmed DEF heater controller ?
Rgds, D.
/ Frozen DEF #5
I have wondered about DEF freezing and giving problems; it got downight cold this last week and my pickup is a RAM 1500 with the little diesel when I filled up last week I made sure to give it a heavy dose of power serve for the fuel. I worried about the def and what it might do or cause as most of my driving is short trips now days, I do let it idle a lot. So far I haven't received any def messages or had any def related issues. I'm pretty sure the def heater only runs with the truck running as it is electric and with the weather being below zero F for a week it should have stressed it if it was going to. This is my third winter with this pickup and no def issues so far, knock on wood, its been doing a decent job for me.
/ Frozen DEF
I'm pretty sure the def heater only runs with the truck running.....
Agreed; I left that background thought out of my post.
The only thing I can see working reliably is having a DEF drainback system in place so lines don't freeze - if the tank is frozen, then the heaters will need to do their thing for a while to thaw the DEF before it will flow. That takes time though, which may not pass EPA requirements (?).
Rgds, D.
/ Frozen DEF #7
DEF is used to reduce the NOx from high combustion temps.
The Nitrogen and Hydrogen from the DEF combine/convert NOx into Nitrogen gas(our atmosphere)and H2O-water vapor.
Since high combustion temps won't happen for some time when very cold,this allows the DEF tank and line heaters time to warm the DEF so it will be ready when needed.
/ Frozen DEF #8
So are we saying the fact the DEF may be frozen while in the tank in very cold weather, is not problem, and it won't hurt anything, the heaters will just thaw it out and it will be ready when it is needed then?
/ Frozen DEF #9
Think I remember reading that some place that it would hold back on errors until it got thawed out. No NOx until it gets warmed up anyway.
I will stick with the 5.9 Cummins for right now do not need any rocket science. Just lucky the 2 tractors RTV and mower are Tier 3 .
David
/ Frozen DEF #10
Yes!
I remember a customer gave me a copy of a Cummins engineering report when aftertreatment was new some time ago.
/ Frozen DEF #11
What number two said. System does not call for DEF until temp is up. My M7 has a symbol saying the DEF is frozen. Continue to run and it will thaw. However if using it at a power level faster than it can thaw, the display will start showing it will limit power to the rate at which it can thaw. An example in the book shows 80%. I've had the display show my DEF is frozen when starting some very cold days but I've never used DEF faster than it can thaw. My high power jobs are tillage and I can't do much on frozen ground. Since I have a KVT transmission, transmission temperature is a limitation. Between 5 and 19 degrees it needs 3 minute warm up before it will propel. At -4 to +4 it needs 5 minutes and -22 to -5 it needs 7 minutes. So the tractor will not even propel until the transmission has time to warm up and during this time the DEF heater is doing it's thing. Its not anything to me because I never start off a tractor or combine in really cold temps without giving it time to warm up.
/ Frozen DEF #12
OK, that all helps my understanding. So I guess the automotive engineers are not crazy after all. I was wondering how in the world could a DEF heater keep your DEF from freezing overnight with killing a battery. Got it now. Thanks all.
/ Frozen DEF
Sounds good as a theory. (Makes sense, not being sarcastic.Well, maybe a bit :) ).
The one guy I was talking to just had to have a recent model Fx50 towed into the dealer on this issue. Didn't get more details, as we both had to go.
I can't think of many (any actually) other liquid vehicle systems designed to freeze solid. DEF Tanks are likely plastic. How many freeze cycles are the tanks rated for ? I now understand why DEF tank heaters often fail, in what I consider to be relatively young vehicles.
Added complexity. Added weakness. That's true, even w/o liquid loads freezing.
Rgds, D.
/ Frozen DEF
Plowing or blowing snow, are the major activities I can picture for Ag stuff re. this DEF issue. Maybe hooking up to a PTO gen in an emergency. I'd expect a good equipment operator (personally owned anyway...) to allow adequate warm up.
I see this as more of a potential issue for road vehicles, than Ag.
Back when TBI gas injection was new (I'm getting old, but beats the alternative :thumbsup:), sales reps used to just leave their cars running at Northern Ontario motels overnight in the Winter. TBI wasn't initially quite dialed in right for that type of cold, so the solution was to just leave the car running.....
Guess that's one solution to avoiding a frozen DEF tank......
Sarcasm aside, I'm now wondering why (cost aside) they don't build DEF tanks with "shore-power" 120Vac "block-heaters" ? For what a new diesel costs today, I'd be willing (seriously) to pay at least $400 for that option.
Rgds, D.
/ Frozen DEF #15
Back when TBI gas injection was new (I'm getting old, but beats the alternative ), sales reps used to just leave their cars running at Northern Ontario motels overnight in the Winter. TBI wasn't initially quite dialed in right for that type of cold, so the solution was to just leave the car running.....
Rgds, D.
Its not considered a problem. DEF freezes but is not injected in a cold engine because DEF is used to convert hot NOX into nitrogen and oxygen (air). When cold the engine isn't emitting enough NOX to be a concern. In the meantime the heater is melting enough DEF for use when the engine is hot and producing high power. My partner is now on his second DEF pickup and the only problem he has had is forgetting DEF and having to buy it at a fuel station at more than double our regular cost. His regular job is in Fargo, ND, so frozen DEF is a half year thing.
/ Frozen DEF
I understand the chemistry and process as described.
I also don't doubt that the DEF tank is designed to make it through the warranty period, in many northern exposures. Trouble is - last time I looked, emissions warranties (road vehicles) are a lot shorter than they used to be. Realizing that this can be a Don't Care issue, if new vehicles are rotated out fast enough.
Would be interesting to compare failure rates southern USA vs. northern Canada/Alaska, for the same model vehicles. Relative MTBF #'s in Eng terms.
I'm betting DEF tanks and heaters will last longer if they don't freeze.
Rgds, D.
/ Frozen DEF #17
my second year with a 2.8 duramax, had lows of -40C for a week and with enough short trips managed to get a ice jam in the def tank where i had at least 12L of def in the tank and the computer read it as empty. so it was warning me to fill the tank and threatening to speed limit me, as the tank is insulated and there was a giant ice cube in there it took a insane amount of heat to unthaw. drove it in cold after and no more problems thinking it was a combination of the cold and the short trips where the heater just unthawed the fluid around it and ended up in an air pocket just a guess as i don't know the internals of the tank.
/ Frozen DEF
Yep, that's the type of issue I'm concerned about.
Winter, short trips with a diesel.... challenging enough already, w/o adding an Achilles heel like this.
I'd like to see a "block" heater for DEF tanks, so you can heat from 120vac. Next closest aftermarket solution I know of are these silicone pad heaters:
Silicone Pad Heaters for Engines | Phillips & Temro Industries
Those are listed for metal applications.... can't remember the surface temperatures they typically hit..... wouldn't do much on the outside of an insulated tank though.....
Rgds, D.
/ Frozen DEF #19
Rgds, D.
It would seem to me if you glued a piece of thin metal (approx. size of the bottom of the DEF tank) to the bottom of the tank and then put the silicone pad on it would distribute the heat well. You only need to get the DEF to 1 degree above it's freeze point so you don't need a high wattage heating pad.
DEWFPO
/ Frozen DEF #20
Sarcasm aside, I'm now wondering why (cost aside) they don't build DEF tanks with "shore-power" 120Vac "block-heaters" ? For what a new diesel costs today, I'd be willing (seriously) to pay at least $400 for that option. Rgds, D.
Have you considered a battery blanket for your DEF tank? You could plug it in with your block heater. I'm sure there is way to do this if the tank is outside.
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
Deutz 4-Cylinder Air-Cooled Industrial Diesel Engine (A63689)
Deutz 4-Cylinder...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
