RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 23,144
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Actually I will start at the neighbor's mailbox, to the left of the pictures(maybe not in pictures), and clear about 2/3 the length of the house. Mostly moving the pile. At the tree is his septic tank, so I have to keep that covered. That pile/berm is the plowed mess from the county going around the turn around. Usually further away from yellow house, but not this year. Will actually touch the pile with the back blade in areas to make sure it is broken up, then turn around and chew with the blower. And keep moving in a little bit at a time. If that doesn't work, I'll drop the blower and go get the BX's loader and use the bucket. Jon
I go through this on occasion after the town plow does their plowing and normally stick with the blower as much as possible. Now, my blower is a rear mount and I've got 46 PTO HP. But piles that high (especially if it's frozen) even bog my tractor down. Using the blower moves the snow quite a distance if it's dry so I don't have to do it twice. Using the loader bucket...well, sometimes there's no room to put the snow (that's what it looks like in your pictures).
Good luck though! That looks to be a real PITA job
