Titan Attachments
/ Titan Attachments #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Anyone have any experience with Titan Attachment brand products. Tooth bars, grapple, pallet forks, etc, ?
Seem to have good prices on their products
/ Titan Attachments #2
I'm about to find out. My toothbar is supposed to arrive Friday. There is other threads with information about Titan Attachments.
/ Titan Attachments #3
I have their 60" box blade and so far it's fine. I am going to weld in a top tray to add weight, but other than that I've no complaints beyond the typical couple weld areas where two welds we not joined at a corner. Those are simple little things that if I see becoming an issue (cracking) I'll grind that area down and replace the weld with an American weld from an American welder... Me.
/ Titan Attachments #4
I have been happy with their 3pt pallet forks and bucket clamp on trailer mover. I also picked up their stump bucket however I have not tried it yet (wanted it to pop out rocks not stumps as sort of a pore mans backhoe). They have excellent pricing however you have to keep in mind it is Chinese quality so welds etc. may not be as good as USA sourced. For my purposes fine.
/ Titan Attachments #6
I'm looking at their hydraulic flail mowers that seem to be a very good price. I think they're a new product for them so I haven't actually found anyone who owns one yet.
I've also been looking at their tree puller.
/ Titan Attachments #7
Assuming you are shopping for the new MX?
I got tomahawk brand grapple and forks for my MX. Seems a good fit and good prices too. Dont know what the titan stuff runs. But tomahawk is worth a look IMO.
Tomahawk Attachments - Factory Direct
/ Titan Attachments #8
The ballast box is very good, don't see any bad welds and the paint is fine. Can't beat it for the price.
/ Titan Attachments #9
I ordered the QA plate attachment with 3 pt & box receiver... came yesterday. Seems solidly built... the packaging was honorific ... the 3 pt link was loose on top of the box in my driveway ...
/ Titan Attachments #10
I have their ballast box, FEL Forks, and JD QA plate. You should first understand why your getting such a great price compared to USA implements, they are made in China, the welds are ok not great, the packaging is sometimes poor and quality control can be hit or miss, that being said, if you own a compact tractor the likelihood of tearing up the implement is rather slim so the money your saving outweighs the fact that you can always touch up a weld if need be. The Forks work great and far exceed the lifting capacity of my FEL and will last forever, I bought one of the first ballast boxes before they had a design change so I can't comment on the new ones but it's a box you fill with concrete and works fine, welds not so great. The JD QA plate is built well, nice and straight and a great price, welds look good. So understand if things are not perfect that's because the money your saving and I'm ok with that.
The best thing about Titan Attachments on TBN is that they don't insult or thrash their customers on a public forum. If you want to share your experience on their thread with some constructive criticism they act professional, they don't call you names or try to degrade you. They also don't practice the mob mentality of getting other members to insult you just to hide their not so perfect implements as other sponsors have done on this forum. So if you don't like being insulted by a company after you spend your hard earned money on their product stick with Titan.
/ Titan Attachments #11
I have a single lid grapple from Titan. Good value for money.. no complaints
/ Titan Attachments
I have a grapple, pallet forks and tooth bar all bought from Titan. Not the cleanest welds but all have worked very well. No problems and free shipping.
these are the same items I'm looking to buy. Dealer wanted $800.00 for his QA pallet forks for $574.00. I see tooth bars for $400.00-$500.00. Titan is $214.00
/ Titan Attachments
/ Titan Attachments #14
I bought a used Titan 6 ft. rotary mower last year. I probably put 5 to 6 hrs on it and it worked well. It seems to be well built and plenty heavy.
The previous owner bought it new, only had it for a year but wanted a bigger one due to mowing so much property. I'm only mowing 4 to 5 acres and some of it is pretty tight getting around buildings and such so the size works for me.
/ Titan Attachments #15
I bought 4,000 Lb clamp on forks with the spacer, 7 tooth bolt on bar, and a clamp on receiver from them over Black Friday (good Sale !!!)
They are defiantly heavy duty and well made.
Close to 300lbs and delivered in less than a week by FedUp and all for less than $420 .....
in my opinion, they are amazing .....
/ Titan Attachments #16
I have their toothbar and clamp on forks and I think they work great! Had to do a bit of grinding to get the toothbar to fit nice and snug, but that is probably because my bucket is "used" pretty well. Good pricing on their stuff and good delivery time, no complaints at all.
/ Titan Attachments
I like the price of their Grapple, but I really don't like the weight. @815LBS It would reduce the loader lift capacity.
I may have to call and see if the 200LB grapple everything attachments has will work ok with my MX.
I don't use my grapple to rip roots out of the ground. I only use it to pick up,large rocks, limbs, trees and brush. So, the 200LB Grapple they have may work for me and not put near the added weight on my loader
/ Titan Attachments #18
I recently had the opportunity to compare a new Titan box scrape to a used Land Pride pretty much side by side. The Land pride had slightly thicker metal in the support and tines. That is confirmed by the manufacturers specs that the Land Pride weighs 20 pounds heavier than the Titan. The Land Pride had bolted on cross supports and most of the cross supports on the Titan were welded. The land pride had weathered some of course. I was rather torn to be honest as the Titan had what I think is a better adjustment system for the tines than the land pride. The Land pride, being used, was $125 cheaper. And due to some slightly beefier areas of support it won out over the Titan. But Ill tell you I would have been fine with either of them. Just couldn't find enough reasons to pass on the savings that came this time with the used Land Pride. The Land Pride was a slightly better box. But only sightly.
/ Titan Attachments #19
I think the tomahawk 66" single lid like I got is only 415#. Dont really notice any difference when compared to the OEM HD bucket.
/ Titan Attachments #20
I have ballast box (very nice!), pallet forks, six-foot box blade, and a tree grabber from them. Fully satisfied, given the price of these items.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2007 Utility Trailers Mfg. FS2CHA 48ft. 40 Ton T/A Flatbed Trailer (A61573)
2007 Utility...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2022 Ford F-150...
