Best tow vehicle for 3 grand? Van, Suburban, or truck.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #21
Regarding a Suburban with a 5.7 V8 and towing capacity... I don't think any combination of gears, transmissions, etc... was spec'd to tow 10K with that engine. 1500 or 2500 series. With the 454, yes. 350, I don't think so. I could be mistaken, but I don't recall any being over 8500# capacity with that engine.
Also, I think the 454s maxed out at 10K per factory specs., but again, check youself to be sure.
Same goes for the vans.
You get in a wreck towing one pound more than rated capacity, even if its not your perceived fault, vulture lawyers will be all over you.
Anyhow, just be sure to check your specs before purchasing and excpecting something more than it is rated to do.
We currently have a 1993 Suburan K1500 with the 5.7 engine. I think its only rated for 7500-8000K. We tow a 7000# car hauler. The car hauler weighs 1500# itself, so we have a usable capacity of 5500# on that trailer.
We had a 3/4 ton 1993 Chevy conversion van before that. And it towed the same trailer just as well.
The van was a conversion van. So it seated 4 captain chairs, and 3 on the back seat, which also folded out into a bed for sleeping. It started rusting out badly, and I wanted 4WD for winter to make sure I got to work, and for driving around off-road on our tree farm. So we sold it and bought the 1993 Suburban. It seats 8. Seats 5 with the rear seat removed. Holds 4x8 sheets of plywood or drywall inside with the rear seat removed and the center seats folded forward, flat. You can even find them with a bench front seat, so that bumps capacity to 9, 6, 5, 4, or 3, depending on which seats you fold or remove.
In my opinion, the Suburban VS Van is a hard one to call. You can haul more inside a van. You can stand up and walk around in a van. If you get a van conversion, you can seat people more comfortably, too. They can be a pain to remove seats for hauling a load, whereas the Suburban (ours, at least), the center seat folds flat. If you have a trailer, you don't need a pickup truck.
If you have kids, friends, family, etc... that you want to take with you, a pickup can get crowded quick.
I have no experience with Ford products. However, I think they make some better towing options than Chevy in the pricerange you're looking for. Good luck in your search.
Just remember, a $3000 truck is gonna be 15-20 years old. Things will break or fail often unless you replace everything at once. Just two weeks ago I lost my radiator in the 1993 Suburban. Replaced it and a couple days later, the top radiator hose blew. Replaced all hoses, and a couple days later the water pump went. The radiator was $125. The hoses were $35. The water pump was $29. And the antifreeze was $17... 3 times! So $51. So a tad over $200 in repairs, and about 4 hours of my time. Belts. Wiper motor. Air conditioning compressor. Brake lines get soft and the metal lines corrode and rust. Heater fans. Brake calipers/drums.... I've taken ours on some long trips in the past few years. I take it twice a year to get our kid from college, about 120 miles each way. Take some tools and a credit card and don't travel at night is about the best advice I can give if you go the old, used rout. :thumbsup:
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #22
A tow vehicle for 3 grand will be a huge risk. Spend a bit more and get a lot more. For around town you might get away with it, but a 200 mile trip with mountains involved? What is your safety worth to you? How much $$ is riding behind you with trailer / tractor / implements? Three grand towing 30 grand makes no sense to me. YMMV.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #23
I agree with blackrams on the manual trans. I'm not much for the slushboxes...
Perhaps a Ford V10 like this one near me: 21 Ford F-25 4x4 - cars & trucks - by owner - vehicle automotive sale
The V10 trucks don't seem to cost what the diesels do. Plus cheaper maintenance and cheaper fuel. I'm a Ford guy, so that's what I'd probably be looking for. A budget of 10-12 grand seems more realistic. Even then, you may have to spend a couple grand over the next few years getting the vehicle to 100 percent.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #24
Perhaps a Ford V10 like this one near me: 2��1 Ford F-25� 4x4 - cars & trucks - by owner - vehicle automotive sale
Engine choice may limit what kind of transmission you can get. Haven't looked into that. What I will say is, there's nothing wrong with either the Ford V10 or the Dodge V10 that was offered for several years, both are powerful engines. There is one problem with them, they are gas hogs.
I'm a diesel guy, diesel costs slightly more per gallon but, I also get better fuel mileage per gallon so, it kind of works out about even. I like the low end torque the Cummins straight six offers. I recently hauled a Ford F450 up to northern Ohio for a gent that I had transported previously for. He said, I see you still have that old Dodge. (BTW, I'm not a Dodge fan, I'm a Cummins man.) He smiled as he said that. I replied that it was good enough to transport his Fords to him. Then I asked what kind of fuel mileage he got with his Fords. He told me his averages.
So, I walked him over to the cab of my truck and showed him the mileage per gallon on the last thirty gallons. He was shocked. My Cummins got as good of fuel mileage hauling his Ford on my gooseneck as he gets with just his Ford and no trailer. Now, there is one thing he is aware of but I didn't repeat to him. I never get in a hurry on the road. I'm normally 5 to 7 mph under the posted speed limit on the interstate. Speed uses more fuel, I'm not in a hurry to buy more fuel. I doubt he ever drives his trucks below the speed limit, probable 7 to 10 over but, those are the guys who are always passing me. That's OK, I just wave as I pass by the fuel stops. ;)
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #25
For as little use that the OP has mentioned, and his budget, I'd think a diesel is out of his target goal.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #26
IMO, stay away from ANYTHING with a lift kit for a tow vehicle...
Aaron Z
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #27
Aaron Z
The ad says 4" life kit... not lift kit... so we're good! :laughing:
craig said:
Nice ride!! Leather interior , 4 wheel drive and with a 4 inch life kit . Also a B&W 5th wheel hitch . It's a V10 Gas. Crew cab. Excellent condition absolutely nothing wrong with the truck! Asking for 10,350 Thank you !
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #28
Ford superduty 1999-2004 with v10 and manual trans can be had for very reasonable prices. I wouldn't shy away from 4x4, even if you don't 'need' it, I often use the transfer case in low range without the hubs locked in just for the gear reduction, when maneuvering trailers or heavy loads in spaces. Just makes it easier on the trans, reguaregardless of Auto or stick.
A base model truck in decent shape can be found in the price range you state. And in Tennessee, the body is less likely to be rusted to heck.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #29
Aaron Z
Agreed, and I wouldn't have an automatic transmission either.
/ Best tow vehicle for 3 grand? Van, Suburban, or truck. #30
Last year I bought a 2003 E350 extended window van with 113,000 miles on a 5.4 triton for $2500 form governmentliquidation.com . Passed Maryland state inspection needed nothing . I put 22,000 miles on it this year , I had to do tie rods and tires . It pulls my 10K trailer with a new holland 1925 no problem . Vans are good buys
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
MGY Shop Heater (A60463)
MGY Shop Heater...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
