Grapple grapples best buy most versitile
   / grapples best buy most versitile #1
apatche1964
john deere 955
i have a kioti ck4010 im looking for a low cost medium duty grapple, any suggestions
   / grapples best buy most versitile #2
Everything Attachments is hard to beat. Well built grapples in a multitude of sizes.
First step is to determine what you will use it for.
   / grapples best buy most versitile #3
I agree. Each operator has their own expectations for a Grapple. I guess that's why there are so many different types. The range is huge from bolt on claws for your bucket to extremely heavy duty rook rake types. If you've not done so you might try to think about your expectations. Then express them here so posters can better guide you.
I bought a second toothed bucket and built a double claw grapple on it. I wanted to be able to carry loose material and/or grapple loose brush without having to swap attachments.
   / grapples best buy most versitile #4
Some of the budget grapples just use bolts for the claw pivots, instead of pins and bushings and grease fittings. Some are made from mild steel, so they're heavy or bend easily. The EA ones are a few hundred more than the budget models but are well made and supported.
   / grapples best buy most versitile #5
I use a Green's Machine thumb and tooth-bar;not a full on grapple but works well.Won't open as "full" as a purpose built grapple but very useful.Around $600 total plus the third function(which you would need for a grapple) or some use the rear remotes if you have them.
   / grapples best buy most versitile #6
Some of the self proclaimed “grapple experts” will soon show up and try to browbeat you into buying their vision of the “perfect grapple” without regard to what you plan to use it for.
   / grapples best buy most versitile #7
Yep. :)
   / grapples best buy most versitile #8
There's a lot of those sold. The productivity change is dramatic isn't it!!!! :)
   / grapples best buy most versitile #10
EA wicked root grapple is best I’ve had and have had a few different ones it’s light but made strong and well I wish it had jic fittings for hydraulics instead of NPT thinking of getting a new one with a larger throat opening
2017 DRAGON 150 BBL ALUMINUM TRAILER (A55745)
2017 DRAGON 150...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2018 DRAGON 150...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
