I have an lx 172 and lx178, two upper level old John Deere riding mowers. I have rough ground on a farm and not anywhere near a pristine super manicured outfit. I don't take big bits in tall grass, and if grass is super high, I overlap my mowing or set the cut level high on the first pass and the come back when done and drop the deck to a lower level.
I hose my decks almost every time I use the mowers. Sometimes i take the putty knife to them. The only problem I have ever had is mowing tall wet grass and essentially asking more of the mower than it was built to provide. Also I keep my blades SHARP. I have extra sets and keep the blades sharp, putting the sharp ones on very often.
Does your JD deck have the "Wash-Port" fitting on the left side? Connect the hose and run the blades when you're finished mowing. Works great if you lift/lower the deck a few times to allow air induced to agitate the debris.
If you don't have the fitting one is easily installed. Port # GX22426 + Washer # 24M7100 + Screw # 37M7458.
I can savvy your frustration with the calendar pages rolling by. I sprung for one of those harbor freight lawnmower jacks a couple years ago and all I can say is that it makes the under deck cleaning, greasing and blade changing one heck of a lot EASIER. Northern sells them as do other outfits and they are worth what ever you gotta pay for one.Thanks for the replies, men. The old gray mare ain't what she used to be!!!!![]()
Could the John Deere kit be installed on my 60 7 Iron deck. Never seen these on the commercial mowers?
I'm limited by age and physical condition to the blade scrape and other methods that were fine years ago. I was hoping there was a spray to create a barrier to stop the grass buildup.
I have a JD with 48 inch deck, and a smooth and thick yard. It's easy to load up the underside of the deck when mowing on damp grass. The physical part is what has me searching for a quick fix. Thanks for all the replies. parsonbw
