Good morning!!!!
   / Good morning!!!! #60,541
Morning all!
Today's challenge is to try searching TBN for the best place to get SSQA Pallet forks. I'm going to use them for moving household goods in/out of storage trailer and some times construction materials.
Somehow I need to do this in and amongst everything else today...
Be well all,
David
   / Good morning!!!! #60,542
Morning all!
Be well all,
David
David, I've had very good service from my Titan 48" x 5,500 lb. pallet forks.
48" Pallet Fork Attachment 55lb Capacity Tractor Forks skid steer quick tach
Titan's product line offers varying fork length and load capacities. Prices are reasonable and they're having a sale right now.
Titan Attachments - PalletForks.com - 8-65-8241
I bought a pair of their fork extensions as well.
   / Good morning!!!! #60,543
David, I've had very good service from my Titan 48" x 4000 lb. pallet forks...
I'm on their site right now! LOL...
My DK50 FEL can lift ~2,700 lbs including the forks, and it is 72" wide, so which forks do I get? 2,500 pr 3,000 lb rated? How wide?
I'm a tad bit overwhelmed with choices... LOL...
I hate still being a n00b with 250 hours on my tractor... Sigh...
Thank you for the referral!
Be well,
David
   / Good morning!!!! #60,544
Be well,
David
I had to edit my original post. I had ordered the 48" x 4000 lb. and Titan had them back ordered but, upgraded me to the 5,500 lb. forks for no extra cost.
I use mine on New Holland which has lift of 5,000 lbs and LS XR4046HC which has similar lift capacity as your tractor. If I was in your shoes I'd get the 48" forks with 4,000 lb. capacity. Weight difference between them and shorter lighter forks is not much IMHO.
You might get a bigger tractor some day too.
Edit: 48" is length of forks. The SSQA frames are all about same width.
   / Good morning!!!! #60,545
   / Good morning!!!! #60,546
You guys have a lot bigger tractors and equipment than I do, but most of you are trending more property, too. I couldn't even use most of the tractors y'all have. A super garden tractor like my 3208 or at most a sub compact, is all I can use. I enjoy reading about them, though.
   / Good morning!!!! #60,547
Randy,
Good to see you buddy.
I bought them. Problem Solved...
Be well all,
David
   / Good morning!!!! #60,549
   / Good morning!!!! #60,550
Once you use those pallet forks a few times, you'll find all kinds of uses for them. I used to leave the 4-in-1 bucket on all the time, now it's the forks that live on the tractor. I can move more wood and brush with them, lift more because they weigh less than the bucket, and even do a little digging if I'm careful. The Titans look like a good choice!
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
Cushman Electric Cart (A55851)
Cushman Electric...
2019 GALYEAN...
2017 Ford E-450 Passenger Bus (A56858)
2017 Ford E-450...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
